Go to Post The mission of FIRST is not just to promote science and technology, but to help every student involved to reach their full potential and achieve their dreams - Mike Ciance [more]
Unread 20-02-2012, 07:45
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Encoder keeps stopping?
Hey. Today I wired our encoder to the sidecar with two PWMs:
+5 (orange) = PWR of #1
A (blue) = SIG of #1
Gnd (brown) = GND of #1
B (yellow) = SIG of #2
and after wiring it I intergrated the Encoder Example to the default robot project. When I ran the code, I went to teleop to check the indicators, and they were all zero, plus it said that the Encoder Stopped. So I tried adding a joystick button that when pressed called the Start VI of the Encoder. What happened is that every time I hit the button to start the Encoder, the distance went down by 0.25. I tried changing the Decoding Type from 4x to 1x and then the distance went down by 1, so I believe it goes down by 1/Decoding Type.
What can cause this problem? Is the wiring okay?
Thanks.
Unread 20-02-2012, 08:17
Re: Encoder keeps stopping?
Did you actually run the Encoder example and make sure it worked? That would verify your wiring.
Unread 20-02-2012, 09:01
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
I ran the Encoder example a few minutes ago and got the same results. (The "Alarm Status" says "Encoder Stopped" and the values don't change)
Is the wiring mentioned in the original post okay?
Unread 20-02-2012, 14:45
Assuming you're connecting to DIO pins (and not Relay or PWM pins), the wiring described in the first post should work.
Is there actually 5V on the center DIO pin? Check the 5V LED on the Digital Sidecar. While you're at it, check the 6V and BAT LEDs too. Are they all lit? How about the Robot Signal Light?
Unread 20-02-2012, 14:52
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
i know it sounds stupid, but try unplugging and replugging the encoder wires from the encoder itself. We had a similar problem, and for whatever reason that worked. Also, if this doesn't work, try reading the digital outs on the front panel. Both should be flashing when you run the motors.
