Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 02-20-2012, 10:00 AM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Changing parameters on the fly?
Originally Posted by bob.wolff68 View Post
This is really big news that I believe VERY few people know of...if I have 'external' access (on the fly) to my program's variables in an interpretive way, well...the possibilities are HUGE.
I'll be trying this with my programmers tomorrow for sure!
bob - Team 1967 Mentor - The Janksters
This feature is one of the most productive things about Wind River's setup. Remember that it is 'C' interpreter, not C++. To get your symbols into the symbol table (and thus accessible) in a usable format (not mangled by the C++ compiler), be sure to put them inside a extern "C" clause.
We use this all the time: to turn on/off the collection of data, play with operating params (like PID constants), enable/disable features while debugging etc. It definitely works!
Good luck!
Unread 02-20-2012, 10:16 AM
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
I personally use LV, so this problem is trivial for us, but would it be possible to have a CSV file stored on the robot that it reads from? So that if you modify the values, it's behavior will change?
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 02-20-2012, 10:28 AM
from the original post:
Originally Posted by DjScribbles View Post
I've thought about attempting fopen or something like that, but that still requires me to filezilla something down there ( or SSH/terminal somehow into the robot)
Unread 02-20-2012, 04:30 PM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Can you access members of a structure? For example:
in your C++ code:
extern "C" {
    typedef struct _PIDConst
        float Kp;
        float Ki;
        float Kd;
    } PIDConst;
     PIDConst iMyPidGain;
then from the VxWorks shell:
% iMyPidGain.Kp = 0.001
Unread 02-20-2012, 10:03 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
No - can't do that directly. The interpreter does not have the benefit of things the compiler/preprocessor would know. Constants are also of no use.
If you know the offsets into the structure you can do it manually with the memory modify commands.
HTH
Unread 02-20-2012, 10:35 PM
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Wow - I just tried it and it certainly works. Really cool.
If only there was an inverse of c++filt...
The debugger also provides a nice way to do this, but with more complex multithreaded applications debugging's bound to get tricky...
SmartDashboard is the future though. Once they can actually get it working, that is
Unread 03-04-2012, 03:03 PM
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
We do this all the time. We have many variables that we can adjust all the time.
you can see the code as part of our 2010 code.
http://www.frc272.com/seminar/Archive/.
We call the LCConfig.cpp. You can change the config file, save it via FTP to the Crio, press a button and have it read in to the running code then have it apply the new settings. Once you like them leave it there. The config is read in when we boot up. Very flexible.
Unread 03-05-2012, 02:31 AM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Well - we gave a shot at the interactive input on SmartDashboard with no luck. It all works on a separate computer as we've all noted, but otherwise...sigh. We tried to also put a button on the SmartDashboard so we could interactively click on the button ... no go...
So, SmartDashboard::GetInstance()->GetDouble() doesn't work... so we use GetString() and then sscanf() to turn it into a double.
Also, using Preferences::GetInstance()->PutString() doesn't work, but PutDouble() and PutInt() work just fine.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 03-05-2012, 01:28 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
You should check out the SendablePIDController, which is part of the SmartDashboard. I'm not sure if it works in C++ because of the double issue... but it works for me in python
And, before there was SmartDashboard, there was WebDMA, which does the same thing as SmartDashboard except with a webserver on your robot.
Unread 03-06-2012, 01:46 AM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
bob
Have you filed trackers for these issues? If they aren't tracked we don't know about them and are less likely to fix them.
http://firstforge.wpi.edu/sf/tracker....wpilib_c_bugs
Thanks,
-Joe
Unread 03-12-2012, 12:58 PM
Da' Mentor Man
FRC #1967
Joe,
Thanks for the link to the trackers -- I filed 3 for:
- SmartDashboard::GetDouble() doesn't work for interactive data.
- Preferences:utString() doesn't work at all
- SmartDashboard:utInt() graphs/logs an incorrect (huge) value once in a blue moon causing graphs to become unreadable until the errant data-point scrolls off the graph.
Bob Wolff
Thanks,
-Joe
