Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 20-02-2012, 10:02
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
Tippy Falling Robots :D
So the other day one of the mentors was driving our collaboration robot. While driving it, it seemed to be ok but when when drove on the bridge. Things turned bad fast. Luckily nothing broke the battery just fell out. It was later discovered that the problem was the battery and compressor were to far back, so moving them forward and closer to the ground will stop this from happening.
Suddenly, a wild prototype appears!
Unread 20-02-2012, 10:17
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Tippy Falling Robots :D
Hate to break it to you, but your bridge appendages are not going to be legal, because they are not one contiguous appendage, as per [G21]
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 20-02-2012, 10:33
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Although Caltran is right, there is an easy fix. Take a plastic or aluminum rod and make a spacer that fits right in between the two arms and bolt it all together and you'll be fine.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 20-02-2012, 10:36
Assuming that it retracts, and the extra rod doesn't get in the way. I don't see any mechanism for retraction.
Unread 20-02-2012, 10:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I've seen a lot of robots that are fairly tippy on the bridge... especially if they start to fall off while trying to balance with a second robot!
We tried it with our robot last night... We tipped it back probably 75 degrees, and it still flopped down on its wheels!
Unread 20-02-2012, 10:47
The R/C'er
AKA: Dontae
Already on it. The robot in the video is an early prototype the finished robot (or robots) that go in the bag will have that problem fixed.
Unread 20-02-2012, 10:49
CalTran's Avatar
Missouri S&T Senior
Ah. Well, in that case, looks all good! Hope you have a great competition!
Unread 20-02-2012, 13:26
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
One note I will suggest to other drivers, if someone is driving on the bridge behind you, do not quickly speed to the other side unless they are fully on, as you will pretty much always flip them over from underneath
Hey bro can you pass the 7/16ths wrench? I only need it for a second hold on...
