Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 19-02-2012, 13:29
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Dividing Speed on Robot Drive
I am trying to divide the speed of the motors...
by 1/2 when Button 1 of Stick 1 is pressed;
by 3/4 when Button 1 of Stick 2 is pressed; and
by 1/4 when Button 1 of Both sticks are pressed.
Where is the best place to add the divide function.
			// Drive
			if(J_stick1.GetRawButton(1) == true)
				R_myRobot.TankDrive(J_stick1, J_stick2);
			else
				if(J_stick2.GetRawButton(1) == true)
					R_myRobot.TankDrive(J_stick1, J_stick2)*3/4;
				else
					if(J_stick1.GetRawButton(1) == true && J_stick2.GetRawButton(2) == true)
						R_myRobot.TankDrive(J_stick1, J_stick2)/4;
					else
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 19-02-2012, 14:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Dividing Speed on Robot Drive
It needs to be placed in the "IsOperatorControl()" loop where TankDrive() is being called now. call the GetY() method of the joysticks to get the value and multiply it by your scale. I would use decimals like 0.25. For example:
R_myRobot.TankDrive(J_stick1->GetY() * 0.25, J_stick2->GetY() * 0.25);
When you don't want to scale keep
In our example below, you forgot to multiply by 0.5 when button one was pressed.
You don't need "== true" in your checks for GetRawButton(). It returns a bool
Brian K
Team 1225 Robotics Mentor
Unread 19-02-2012, 21:19
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
You should have a scaleFactor variable and have the buttons modify it.
bool j1Btn1 = J_stick1->GetRawButton(1);
bool j2Btn1 = J_stick2->GetRawButton(1);
float scaleFactor = 1.0;
if (j1Btn1 && j2Btn1)
    scaleFactor = 0.25;
else if (j1Btn1)
    scaleFactor = 0.5;
else if (j2Btn1)
    scaleFactor = 0.75;
R_myRobot.TankDrive(J_stick1->GetY()*scaleFactor, J_stick2->GetY()*scaleFactor);
Unread 20-02-2012, 08:07
FRC #0539 (Titans)
Alright thanks, I did not know to use the GetY after the joysticks. For now it has all been working because I had just set the motors up as 2 different declarations and it worked there. So I will be switching it over today because its just much smoother.
Thanks,
Davis
FRC Team 539
Unread 20-02-2012, 10:34
jalburty jalburty is offline
Joe Alburty
AKA: Joe Alburty
FRC #1763 (Paseo Pirates)
jalburty will become famous soon enoughjalburty will become famous soon enough
Send a message via ICQ to jalburty
Pardon my ignorance (or misreading of the post), but how do you get away with calling the TankDrive function (method?) with what looks like different data types as parameters? Is this what's known in C++ speak as "polymorphism"?
vs
Unread 20-02-2012, 11:32
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Yes, that is polymorphism. Basically the function that is used is determined by the parameter types you pass into the function.
Inside the class it defines each different input parameter arrangement with the same function name, and you automatically select between those different functions by the parameters you provide.
Unread 20-02-2012, 12:47
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
It is a form of polymorphism. Function overloading and templates are what is known as static polymorphism. When speaking with most C++ programmers though, polymorphism generally refers to dynamic polymorphism, implemented using function pointers and virtual functions. Static polymorphism is decided at compile time, and is based upon the visible type of the objects to the compiler. Dynamic polymorphism, however, is actually based upon the run-time type of the object.
