Go to Post Such reasonableness will not be tolerated! This is teh interwebz! - pfreivald [more]
Unread 18-02-2012, 11:38
Captain Planet Captain Planet is offline
Apprentice Programmer
FRC #2500 (Herobotics)
Captain Planet is an unknown quantity at this point
Molon Motor Legality
I'm pretty sure the Molon chm-2435-1 is not legal, but I want to be sure. Could an expert help?
Unread 18-02-2012, 11:49
Re: Molon Motor Legality
[R48] attached. The intent of the rule is to list the only permissible motors and actuators. The way it's worded, it could be interpreted to mean it's a subset of the list of permissible motors and actuators. But that's not the intended meaning.
Unread 18-02-2012, 23:20
beiju's Avatar
beiju beiju is offline
Growing Chief Delphi Addict
AKA: Will Pryor
FRC #3120 (RoboKnights)
beiju is an unknown quantity at this point
And just in case you want to press your luck and argue that wording at the competition, the manual instructs you to "when reading these rules, please use technical common sense (engineering thinking) rather than ‘lawyering’ the interpretation and splitting hairs over the precise wording in an attempt to find loopholes." (4.1 Robot Rules)
Unread 19-02-2012, 21:28
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
The motor included in that complete assembly is not legal.
However, if you want to use the gearbox and turntable, you could remove the Mabuchi motor from the assembly and substitute a legal motor and then be able to use the rest of the assembly.
I don't have one of the "Molon chm-2435-1" assemblies to be sure, but it looks like you could remove the Mabuchi motor from the gearbox and replace it with the BaneBots M3-RS395-12 motor and have a legal assembly. In order to do so, you would need to remove the pinion gear from the supplied Mabuchi motor (if it is possible to do so) and instead put it onto the BaneBots M3-RS395-12 shaft.
This approach of taking an existing COTS assembly, removing the original motor from it, and replacing it with a FIRST-legal motor, is a common approach used by FRC teams.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 20-02-2012, 12:02
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
This of course ignores the fact that the rules get constantly lawyered back at us...
