Go to Post Wow, 3 people able to draw their designs using text in a script processor program. I guess I wasted my time learning all that CAD software - Gary Dillard [more]
Unread 20-02-2012, 12:30
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Using throttle to manipulate Autonomous Mode
I am attempting to help the students code in multiple autonomous modes for multiple different positions. We are currently testing two different ones and ran into a problem. Whenever we enable it tries to do both autonomous modes and kind of 'jumps' around. Are we doing something wrong?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 20-02-2012, 12:34
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Re: Using throttle to manipulate Autonomous Mode
Are the conditional terminals in the while loop set to Stop If True, or Continue If True?
If they're set to Stop, then that means that the while loop will run when the throttle isn't at 1/-1, which is the opposite of what you want.
Unread 20-02-2012, 12:39
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Ah, I see got it now... I knew it was something simple, we'll be testing it in a few minutes hopefully it will work now. Thanks!
Unread 20-02-2012, 12:40
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
This may not be what your looking for, but we have found it easier to use inputs from the Driver Station itself instead of a joystick. It allows you to set multiple autonomi up and accurately pick which one to use, instead of relying on a throttle which may get bumped.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 20-02-2012, 14:56
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
instead of using axis=1 or axis=-1, use axis>0 and axis<0. It is (almost???) impossible to get it at exactly 1, so both would be false, meaning that both would run
Unread 20-02-2012, 20:15
The other comments will improve the code, but you will still find an odd jerk at the beginning as the while loops will both run at least once. You may find it even a bit better to surround the loop with a case statement and change the loops to run forever. The case can be the Boolean results of the compare, or you convert it to an enum or integer using scaling, and put the code in various frames of the case.
Greg McKaskle
Unread 20-02-2012, 20:54
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
That has got to be the most creative use of the while loop I have ever seen! I would suggest that, since has already been mentioned, you put your code into a case structure, and you use the DS switches wired into a build array. Then you can do a boolean array to number and have up to 2^8 autonomous modes!
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
