Go to Post A team does not achieve "Powerhouse" status by dominating every once in a while... they achieve that status by consistently dominating every year. - Jon Jack [more]
Unread 20-02-2012, 15:11
random_hero random_hero is offline
FRC #3297
random_hero is an unknown quantity at this point
Defense Question
Regarding rule G20:
[G20]
Robots in contact with the carpet and/or Key on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation.
Does that mean if we are playing defense on our own end of the court, we can't extend to 84" tall? It's my understanding that the entire court is carpeted. Is there anywhere on our own side of the court where we can be 84" tall? This rule is confusing.
Thanks in advance.
Unread 20-02-2012, 15:18
Andrew Lawrence
Posts: n/a
Re: Defense Question
Nope. You can only go a max. height of 60". Unless you are on the bridge, you can't be on the other side and extend. ALTHOUGH, if you set up a net 84" tall and the maximum width on the center bridge, you could do a pretty good job of blocking a feeder bot, I suppose.
Unread 20-02-2012, 15:19
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
On your half of the field, the area between where you are driving and the barrier, you can only have your robot be 60" tall. Once you go over the barrier, you can be up to 84" tall. This is meant to in conjunction with the 14" extension rule to stop net robots we saw in 2006 I believe.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
