#16
Re: Runaway CIM motors
Thank you for the tip. We did stop and check all connections to make sure we were not shorting anywhere and everything looked good. We will check again when we meet up this evening.
#17
If you could check the jumpers, reinstall the PWM cable and let us know what happens when you power the robot, when you enable and then what you see on the Jaguar during each condition. With the PWM installed, does the motor spin immediately when power on the robot?
#18
See if you flipped the input with the output on the jags. We (i) did that and fried 2 jagur
#19
Steven,
If limit switches are not used, there must be jumpers in place on the Jag. |
