ok what im trying to do is have a button not just control the motor speed but when im moving around with (x,y) i wanna to be able to push a button to slow motor but still use (x,y) to move then when i release it, it goes to normal speed
possible?![]() |
Re: Robot main motor control
here you go. you can change the .5 to whatever you want. the false of this is just wiring the axis directly to the terminal
possible i can have it reverse? so its slow to .5 speed then when button to 1.0 ? |
Yes, just reverse your cases. Make your "True" case read "False" and vice-versa.
