Go to Post Given a choice between giving a man a fish and teaching him to fish, you always want to teach them to fish. But sometimes that involves showing him how to put the worm on the hook first. - dlavery [more]
Unread 20-02-2012, 19:31
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Problem with camera
Theres an update for the utilities. Run that. ReSetup the camera. Put it back on. Working camera. Search before posting
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 20-02-2012, 19:45
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
The FRC camera setup tool shipped before it was working properly. Reset your camera to factory default (Unplug power, press and hold reset button, plug back in power and wait for the yellow light. Keep holding the reset button till it goes away and comes back on, then release the reset button.)
Next, connect to the camera via an ethernet/crossover cable. Set your IP to 192.168.0.xx (xx being any number from 1 to 89). Open an internet browser and navigate to 192.168.0.90. You'll be prompted to set a password. Write your password down along with your login (root).
After setting a password, hit "Setup">>"TCP/IP". There, you are able to manually set your camera's IP.
Unread 21-02-2012, 14:55
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
The updated camera configuration tool can be found here.
Or, to manually configure the camera, look at this post.
