Go to Post In any case, I'd like to remind everyone to practice gracious nonexpansionalism while in your pit. - sanddrag [more]
Unread 20-02-2012, 19:10
funggiss's Avatar
funggiss funggiss is offline
http://metrohomeschoolrobotics.o rg/
AKA: Trevor Stacy
FRC #1825 (MHR Cyborgs)
funggiss can only hope to improve
Problem with camera
We are useing an axis 206. After we use the imaging tool the camera works on the robot untill we turn it off. When we turn it back on it has an orange light around the lens and no longer gives a signal. We have to reset the camera before the imaging tool will see it. Ideas? Thanks
Metro Homeschool Robotics 1825
MHR Cyborgs
Motto Think out side the cube
Robot 2009 Vomitron
Awards 2006 st louis Rookie Inspiration Award
2009 greater kansas city finalist
2010 greater kansas city quality award
Unread 20-02-2012, 19:31
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Problem with camera
Theres an update for the utilities. Run that. ReSetup the camera. Put it back on. Working camera. Search before posting
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 20-02-2012, 19:45
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
The FRC camera setup tool shipped before it was working properly. Reset your camera to factory default (Unplug power, press and hold reset button, plug back in power and wait for the yellow light. Keep holding the reset button till it goes away and comes back on, then release the reset button.)
Next, connect to the camera via an ethernet/crossover cable. Set your IP to 192.168.0.xx (xx being any number from 1 to 89). Open an internet browser and navigate to 192.168.0.90. You'll be prompted to set a password. Write your password down along with your login (root).
After setting a password, hit "Setup">>"TCP/IP". There, you are able to manually set your camera's IP.
Unread 21-02-2012, 14:55
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
The updated camera configuration tool can be found here.
Or, to manually configure the camera, look at this post.
