Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 20-02-2012, 19:47
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
No cRIO2 Robot Communication - HELP?
CD,
Been busy building the robot with sophomore team so finally go around to firing up the new cRIO2 and do not have robot communication.
I've setup the cRIO for the past 2 years so I am familiar with the FRC drills:
1) Labview install from USB drive, 2) Labview updates; 3) Classmate imaging;
4) setting proper IP addresses, 5) Imaging cRIO ; 6) Downloading baseline code using team IP address.
I've done all that have all green lights flashing but cannot communicate with cRIO via F1 enable or mouse enable. What have I forgotten?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 20-02-2012, 21:51
marccenter's Avatar
Re: No cRIO2 Robot Communication - HELP?
Solution found - windows firewall and Microsoft Security Essentials both disabled on Classmate PC operating with Driver Station Labview Software
Marc Center
