Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
Unread 20-02-2012, 19:31
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Java Encoder Limitation?
Is there a limitation to the number of encoders we can have? When trying to add more than 4 in Java, we get the following exception:
[cRIO] Uncaught exception in Thread.run():
[cRIO] on thread edu.wpi.first.wpilibj.defaultCode.DefaultRobot - main
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: There are no encoders left to allocate
[cRIO] at edu.wpi.first.wpilibj.Encoder.initEncoder(Encoder. java:76)
Unread 20-02-2012, 21:31
patrickviolette patrickviolette is offline
FRC #1318
patrickviolette is an unknown quantity at this point
Re: Java Encoder Limitation?
the quadrature encoders seem to be throwing the exception (line 76 of the Encoder class).
it seems like you can allocate more encoders as long as they are 2x or 1x encoders.
Unread 20-02-2012, 21:40
FRC #1318
use the constructor Encoder(int sourceA, int sourceB, boolean reversed, EncodingType type) and pass in EncodingType.k2X and you can make as many encoders as you want.
Unread 21-02-2012, 22:14
Worked! Thanks!
