Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Unread 20-02-2012, 22:57
Roceres Roceres is offline
FRC #1572 (HammerHeads)
Roceres is an unknown quantity at this point
Re: Digital side car signal light on but not blinking?
Originally Posted by Akash Rastogi View Post
Luckily we've got 4 DSCs, not sure what caused the problem with this DSC, but we will post up if we figure out what was wrong.
I would love to hear if the DSC swap worked for you! Good Luck!
Unread 21-02-2012, 00:01
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Think you missed a post
Originally Posted by carterh062 View Post
I then disconnected the digital sidecar, and took a new one, and put our wires in there. The new digital sidecar worked. I suspect that we had a faulty dsc, but it could have been in part healed by the reimaging. SOLVED
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 14-03-2012, 21:17
I'm the lead programmer on Akash and Max's team. I reimaged the whole thing for LabView and reformatted to v43 (and then back to java)--to no avail. I then disconnected the digital sidecar, and took a new one, and put our wires in there. The new digital sidecar worked. I suspect that we had a faulty dsc, but it could have been in part healed by the reimaging. SOLVED
I found that replacing the Digital SideCar worked too! Reimaging the cRIO was not necessary.
