Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 19-02-2012, 14:51
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach - FRC Under Development
FRC #6370 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
3481 Bronc Botz GOING "Battle Botz"
TEASE...
EQUALLY lethal flipped either way... ;-)
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- Head Coach / Founder - FRC 6370 Texas Titans < FRC and VEX teams under development - VRC 15842a >
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 19-02-2012, 14:53
Re: 3481 Bronc Botz GOING "Battle Botz"
**A couple more pictures***
TEASE...
Unread 19-02-2012, 15:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Really loving this chassis, it looks a bit like ours but better.
How do you like the Colsons? Look like the hot wheel of 2012. (Even though teams in NE have been using them forever)
-Dustin Benedict
Unread 19-02-2012, 16:26
THANKS, Dustin!
The Colson's are great... a lot to set up though... we had to lathe a nylon insert that was also broached to hex... and then the slightly-larger insert had to be pressed into the wheel hole... AFTER this was done with an Arbor Press... we invested in a 20-ton Shop Press for such future endeavors as well as present ones!
Our default is to first use IFI/VEX Pro products as a solution, including wheels/riveted-tread... but, we determined the metal rims were just not right to get over the center-barrier. AND the friction coefficient of the Colson's is great... so, we are able to _push-back_ with authority in low-gear using 4 CIMS 6-wheel drive.
--Michael
Unread 19-02-2012, 16:37
thefro526's Avatar
Mentor for Hire.
Our Off-Season prototype used 4"x2" Colsons although we made our inserts from AL Rod and pressed them in... using a vice of all things. Seems like the big reason that many teams shy away from Colson wheels is the lack of an 'easy' way to make them work with normal FRC drivetrains. I hope they work well for you, that drivetrain looks like a mean one.
-Dustin Benedict
Unread 19-02-2012, 19:59
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Wow, you sure did a number on those SuperShifters. How do you deal with a drop center when reversed? Or is there none?
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 19-02-2012, 21:05
ParkerF's Avatar
ParkerF ParkerF is offline
Learn it. Teach it. Spread it.
AKA: Parker Francis
FRC #0118
ParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond repute
The gearboxes are actually standard AM shifters. No third stage like the super shifter. And the drive just looks cool upside down; there are no plans to use in in this manner, hehe.
And thanks for the compliment, Dustin. I'm really happy with how the drive came out.
-Parker
Team 148 Alumnus - '07-'11
Team 3481 College Mentor - '12-'14
Team 118 Mentor - '17-Present
Unread 19-02-2012, 22:13
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Sb28000 is on a distinguished road
How did you guys attach the sprockets to the hubs/Colsons? i would assume some sort of stand-offs or spacers, but I can't really tell from the photos. Other than that though, it looks awesome. I love the powdercoating, it makes it look really sharp.
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 19-02-2012, 22:25
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
This robot is looking great, I really like the choice to go with Colsons (though I am biased). Nice work integrating the AM shifters into the plates. Looking forward to seeing more.
Unread 20-02-2012, 09:54
ParkerF's Avatar
AKA: Parker Francis
FRC #0118
The sprockets are attached to AM .500" hex hubs which are just next to the wheels on the live axles. Spacing is kept with e-clip slots (no spacers to worry about, whew!).
-Parker
Unread 20-02-2012, 13:42
Sb28000's Avatar
FRC #2656 (Quasics)
-Parker
Ohhh, okay, makes sense. I was thinking that they were dead axles, so the sprockets would have needed to be attached to the hub and/or wheel, rather than just the shaft. Thanks for the details.
Unread 21-02-2012, 00:24
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Looks great! Are y'all going to Alamo? And who did yalls sheet metal?
Unread 21-02-2012, 01:03
Matt, we're a San Antonio team... so, we'll be at the Alamo Regional where we won last year, our rookie year, with 16 Bomb Squad and 148 Robowranglers.
Next up is Dallas-East... and then, hopefully, St. Louis.
Our sheet metal and machine shop sponsor is www.m2global.com
THANKS for the compliment... looking forward to seeing 2158 at Alamo!
--Michael
Unread 21-02-2012, 09:57
Brandon Holley's Avatar
Super slick chassis! Nice integration of the AM shifter into the sidepanels of the drive system. Super clean.
I'll echo the sentiments of my fellow Colson bretherend (Foss and I have built up quite a contingent), they are really solid wheels. Many people think they're a lot of extra work, but after using them for a longtime now, I think they're actually easier to integrate when looking at the whole picture. They are also very cheap which makes them even more enticing.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
