Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 21-02-2012, 06:50
tinyclark tinyclark is offline
AKA: Matt Clark
FRC #0228
tinyclark is an unknown quantity at this point
Jittery Autonomous Code {Java}
In autonomous, i try to run the following code:
try {
            encLeft.start();
            encRight.start();
            encLeft.reset();
            encRight.reset();
            while (((encLeft.getRaw() > -14797) || (encRight.getRaw() > -14797)) && (this.isAutonomous())) {
                //System.out.println("Left:" + encLeft.getRaw() + " Right:" + encRight.getRaw());
                if (encLeft.getRaw() < 14797) {
                        motor_leftFront_J.setX(.5);
                        motor_leftRear_J.setX(.5);
                } else {
                    motor_leftFront_J.setX(0);
                    motor_leftRear_J.setX(0);
                if (encRight.getRaw() < 14797) {
                        motor_rightFront_J.setX(-.5);
                        motor_rightRear_J.setX(-.5);
                } else {
                    motor_rightFront_J.setX(0);
                    motor_rightRear_J.setX(0);
            Timer.delay(.5);
            encLeft.reset();
            encRight.reset();
}catch(Exception e){
The output this produces is a very jittery running of the code, as if it sends the commands, and then immediately after sends it a stop command, following which it repeats. The teleop code works fine, so i know that it is updating the output frequent enough, and it never catches any errors... Any thoughts? Thanks
~Matt Clark
Unread 21-02-2012, 08:23
Re: Jittery Autonomous Code {Java}
I have a thought.
Your while() loop is running as fast as it can, with no pauses. It might be starving the communication task, which could result in the hardware occasionally shutting down the motor outputs due to a lack of communication. Put a short wait (ten milliseconds might be good) inside the loop and see if that helps.
Unread 21-02-2012, 15:43
AKA: Matt Clark
FRC #0228
Tied with:
Timer.delay(.01);
Timer.delay(.02);
Timer.delay(.001);
Timer.delay(.005);
Still no improvment.
Unread 21-02-2012, 16:39
Are the motors being controlled by those Jaguar objects also being controlled by a Drive object? I don't even know if that's possible in Java, but if it is, you could be seeing the Motor Safety keeping the drive motors turned off because you aren't calling a Drive command every 100 milliseconds.
Unread 21-02-2012, 16:47
AKA: Matt Clark
FRC #0228
Thank you so much!
In my robotInit() I initialized my RobotDrive() that I user later in teleop, and that is what kept stopping the motors. Moved the RobotDrive init to my teleop init and it works perfectly now!
