Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 21-02-2012, 09:02
Re: should FP gearboxes work in both forward and reverse?
SMC,
The gearboxes can be run in either direction. However, the FP motors have a thermal breaker internal to the motor. When driving up, you may be over taxing the motor and it is tripping the thermal device which gives you the stutter you describe.
Unread 21-02-2012, 11:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Last year we had a FP on our arm. We could get the FP motor smoking hot with no stutter. We were using a jag & a big breaker. We eventual limited the output command to the jag to keep the current to a reasonable level, but that is a different story. Maybe it is the self resetting circuit breaker doing its thing?
Different years gear boxes come with different tooth pinions. It might be that you managed to get a smaller pinion installed. It will work on low load, but skip on high load.
The FP gear box is used on an electric kiddie car. It will run forward & backward. They are as close to indestructible as anything in First.
Unread 21-02-2012, 11:29
Originally Posted by smcmahon View Post
2012 KOP Fisher Price gearbox and motor
Al,
I couldn't find documentation anywhere that says the FP 00968-9013 motor has an internal thermal breaker.
Did you guys take an FP 00968-9013 motor apart and find a breaker inside? Or perhaps run some tests?
Unread 21-02-2012, 12:48
If your FP has the breaker it is visible from the end of the motor. It is connected directly to one of the power input tabs. Use a flashlight.
Unread 21-02-2012, 13:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you want to isolate the problem as to programming or hardware, just reverse the motor wires where they connect to the speed controller. The motor will run backwards when commanded to run forwards.
DO NOT switch the power wires to the speed controller! only the motor wires
Unread 21-02-2012, 13:30
Are you saying that some FP 00968-9013's have a breaker, and some do not???
Unread 21-02-2012, 13:45
I am saying that some FP motors have a breaker and some do not. I do not have a cross reference as to all FP motors that are available for FRC use this year.
Unread 21-02-2012, 14:49
The OP said he was using a 2012 KOP Fisher Price motor, which would be the FP 00968-9013. I am told that model does not have an internal breaker.
Unread 25-02-2012, 20:57
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
As a programmer (who has seen motors behave this way many times), I would typically relate this to a software problem. Typically motion like this is described when in one part of the code the motor is being set to a certain speed, while in another part of the code it is being set to a speed of 0.
Admittedly, it could be other things, and as stated above, switching the leads to the motor end of the speed controller could tell you a lot about the root of the problem being in hardware or software.
www.sharkattack744.com
Unread 25-02-2012, 22:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
How about the 00801-0673 F-P (the 2011 KOP FP motor)? does it have an internal breaker? I remember the 2010 KOP FP motor did because we had some problems with our winch tripping the breaker (I was with 2849 that year). But I have no idea about the 2011 one. I only have two by accident and when the I got scared about using the BB motors in my drive, I switched over to these that happened to buy on a lark from AM in the fall.
Joe J
Team #88, TJ2
Unread 25-02-2012, 22:39
I'm not sure about the 9013 breaker either. I was hoping someone could take a look like Al said and verify.
Unread 25-02-2012, 22:44
AKA: Dr. Joe
FRC #0088 (TJ2)
My only two are in the bag!
Team #88, TJ2
