Go to Post Scientists ask Why, Engineers ask Why not. - Rohith Surampudi [more]
Unread 21-02-2012, 11:03
Re: getting distance from camera
Originally Posted by tilky View Post
ummmmm....is the global variable supposed to be there?
If by "the global variable" you mean "Target info" and if by "there" you mean "in Robot Global Data.vi", then yes. If you mean something else, please ask again with more specific words.
Unread 21-02-2012, 11:39
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
its not there. There is only enable vision, image size, and LED Toggle Rate.
Unread 21-02-2012, 11:55
Did you follow the instructions for adding the rectangular target processing code to your robot project? Doing that properly will replace the robot globals vi file with one that has the target info included.
Unread 21-02-2012, 22:54
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
can you post a link of where to find that tutorial?
Unread 21-02-2012, 23:47
It's Tutorial 8—Integrating Vision into Robot Code. Find it, and all the other LabVIEW Getting Started Tutorials, on the Tutorials tab in LabVIEW.
Unread 22-02-2012, 09:28
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
is there anywhere else i can find it, my computer is stupid and won't update the labview home screen with the frc update
Unread 22-02-2012, 10:27
You really do have to install the LabVIEW update. If you haven't done that, you're missing much more than the tutorials. You're also not in compliance with the rules.
What does "won't update the LabVIEW home screen" mean? What happens when you try to run the update?
Unread 22-02-2012, 21:08
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
i install that, and everything gets installed, but the start screen for labview doesn't change.
Unread 22-02-2012, 22:57
What all does the unchanged start screen say? Does it have the "LabVIEW FRC 2012" text at the top and the FIRST logo at the bottom?
You might need to reinstall LabVIEW. I'm wondering if it got loaded properly in the first place. How did you install it?
Unread 23-02-2012, 09:08
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
i installed it from the flash drive. all of the wpi robotics vis are in there, but the home screen doesn't change.
Unread 23-02-2012, 10:44
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
when you click on one of the tutorials, is it a webpage, a pdf, what is it?
Unread 23-02-2012, 11:09
The Tutorials are a single webpage located on your installation at:
C:\Program Files\National Instruments\LabVIEW 2011\manuals\FRC_Programming_Guide\index.html
