Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 20-02-2012, 17:04
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
getting distance from camera
the title explains it all. how would you use the reflective tape to find the distance from the camera to it
Unread 20-02-2012, 18:17
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: getting distance from camera
If you unbundle the target info global variable, you will see that one of the variables calculated is distance
Unread 20-02-2012, 18:38
Kazel's Avatar
Kazel Kazel is offline
FRC #3414
Kazel is an unknown quantity at this point
Hi,
Our team is having trouble integrating the target info into our main teleop.vi. We tried copying the Rectangular Processing example vi into our main project (the vi that only runs on the computer) and then placing it in our main code. However, whenever I try to run the code with this vi placed anywhere in it, the code doesn't work. I tried removing the vi and the code worked normally. Has anybody figured out the best way to actually use the target info?
Unread 20-02-2012, 20:00
There is a tutorial, available on the launch screen that walks you through the basics of the Rectangle example.
There are actually two different implementations, one targets the laptop, and one targets the cRIO. The cRIO one already has some amount of Robot Main and a Vision Processing.vi that incorporates the rectangle processing. As the tutorial explains, you open the vision processing and do a Save As and include dependencies to save it to your robot project. This will overwrite the Vision Processing VI and the Robot Globals, which should be what you want, but if you have added your own globals, you need to merge them.
Greg McKaskle
Unread 20-02-2012, 20:54
Kazel's Avatar
FRC #3414
Wow, can't believe I didn't see that tutorial a long time ago. Thank you very much! I had copied our current project from another computer, and it turns out I was having some path issues, but once I got those sorted out it worked fine!
Also, I apologize for hi-jacking this thread...
Unread 21-02-2012, 08:05
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
where is target info global?
Unread 21-02-2012, 08:18
the target info global is written to in the Vision Processing VI and defined in the Robot Global VI. By default, no code in your project is reading it. You should copy/paste the global node or drag it from the project and select the right variable.
Greg McKaskle
Unread 21-02-2012, 08:36
If you have followed the instructions for integrating the rectangular vision target code into your project, the Target info global variable should be with all the other global variables, in the Robot Global Data vi.
Unread 21-02-2012, 09:19
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
ummmmm....is the global variable supposed to be there?
Unread 21-02-2012, 11:03
If by "the global variable" you mean "Target info" and if by "there" you mean "in Robot Global Data.vi", then yes. If you mean something else, please ask again with more specific words.
Unread 21-02-2012, 11:39
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
its not there. There is only enable vision, image size, and LED Toggle Rate.
Unread 21-02-2012, 11:55
Did you follow the instructions for adding the rectangular target processing code to your robot project? Doing that properly will replace the robot globals vi file with one that has the target info included.
Unread 21-02-2012, 22:54
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
can you post a link of where to find that tutorial?
Unread 21-02-2012, 23:47
It's Tutorial 8—Integrating Vision into Robot Code. Find it, and all the other LabVIEW Getting Started Tutorials, on the Tutorials tab in LabVIEW.
Unread 22-02-2012, 09:28
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
is there anywhere else i can find it, my computer is stupid and won't update the labview home screen with the frc update
