Go to Post Happy 6 days till FIRSTmas! (and Happy New Year, but that pales in comparison =D) - VKP [more]
Unread 12-02-2012, 10:00
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: How are you getting over the 4" bump?
Our frame's extruded aluminum (30x30 hand cut and welded). We toyed with a mechanized skid plate, treads, etc. In the end, one of the mentors and a student came up with the idea of putting angled braces on wither side of the front wheels.
Top view:
BBBBBBBRACE
Wheel
BBBBBBBRACE
Side view: (W=wheel)
Frame
WBrace
WBrace
WBrace
WBrace
The first wheel goes up, the skid braces hit and get you up then the rest of the 8 wheel drive takes over. Makes for a bumpy ride but in the end, it works. However you attach it, make sure they've got good welds/attachments and something like teflon on them to make things easier.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 12-02-2012, 12:40
Squillo Squillo is offline
AKA: Cynthia Hannah-White
FRC #2465 (Kauaibots)
Squillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant futureSquillo has a brilliant future
Top view:
BBBBBBBRACE
Wheel
BBBBBBBRACE
Yeah, that's what we did. At least I think it is - I couldn't figure out how to describe it, and you've at least made a stab at it. But we have the "braces" (VAGUELY like fenders; our plywood prototypes looked like fenders, but the final ones are just tubes of aluminum defining the outline of the 'fender') just on the outside of each wheel. They are made of tubular aluminum and the "braces" actually hit the bump before the wheel, lifting the (8" mecanum) wheel up a little so it can just slide over the bump. The chassis is high enough that it doesn't touch the bump in the middle. So we go over 2 wheels at a time (budump, budump). It works.
Unread 18-02-2012, 00:58
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
We went with a higher riding drive this year, so a good amount of speed should do it.
Most teams will probably go with the pneumatic wheels from mcmaster, and maybe have a guide-rail system under their chassis. No need for moving parts when you have a moving bot
Unread 19-02-2012, 17:53
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Two words: Tank Treads.
Unread 19-02-2012, 18:19
Shelbers2486 Shelbers2486 is offline
FRC #2486
Shelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to beholdShelbers2486 is a splendid one to behold
My team machined wheel mounts for our drive train that had skid plates on the front to get us over the bump. We are using just a basic 4 wheel mecanum drive train.
Unread 21-02-2012, 03:17
(emphasis added)
Update: I believe I spoke too soon. At this point, it does NOT work. At least, it does not work with our plywood 'bump'. It worked great when tested on our 'chassis-only' bot, but with the extra weight of the actual bot, no dice. We're still thinking it might work with the steel bump, but if not, no big deal, we can just zip over the bridge. And we're going to be so busy scooping up balls and scoring that it probably won't matter that much. We hope.
Unread 21-02-2012, 09:41
Brandon Holley's Avatar
We're getting over the bump very easily and cleanly with a relatively simple system. It's an 8WD, with a specialized cutout in the center that prevents us from high centering on the top of the bump itself.
You can see us (125) crossing the bump a couple times in this video: http://youtu.be/HBwPsmAPN5M?t=53s
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 21-02-2012, 11:15
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Originally Posted by Mr V View Post
Wow, that's a great video. Really neat to see what other teams come up with.
Unread 21-02-2012, 11:16
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Two Words: We're not.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 21-02-2012, 11:45
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
On our robot we simply give our pneumatic wheels full throttle from stop and the front wheels come off the ground and the robot rockets over the bump. We're pretty excited about it.
"No, you can't use the Kinect to do pelvic thrusts."
Unread 21-02-2012, 13:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're driving over one of the bridges to get over the barrier.
Unread 21-02-2012, 16:11
Intel i7 Intel i7 is offline
FRC #3540 (Wildcat Robotics)
Team Role: Driver
Intel i7 is an unknown quantity at this point
this (once it finishes uploading) is how we are getting over the bump. Note that we are on a dead battery (running for about 30min) and only running on 3 out of 4 motors
http://www.youtube.com/watch?v=PZsMWhK-vNU
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
Unread 21-02-2012, 20:32
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Thanks, for the record I was very skeptical about this system. I'd seen a number of videos with just a stripped down chassis going over the bump and wasn't sure that a competition weight machine could make it over in the same manner. So I insisted on the test in that video before moving past the wooden prototype and cutting aluminum and poly carb.
Since it did pass that test we proceeded and I'm proud to present the production version (sans disquising). Doing the bump part 3
Unread 21-02-2012, 21:34
Chris is me's Avatar
AKA: Pinecone
I think this is the most efficient use of limited time. The bridge gets you over the field and scores points. The bump is clearly optional while the bridge is clearly mandatory.
But that's just me.
Unread 21-02-2012, 23:42
Mr V's Avatar
FRC #5588 (Reign)
But that's just me.
Or you build something that manipulates the bridge and gets you over the bump too.
