I posted this yesterday in another sub-forum, but apparently that one doesn't get much viewership, and I didn't get a single reply. So, forgive me if this is too much like a bump, but I think I'm not the only one who would like to see this answered:
I've been looking for an official document that defines the various patterns that the Robot Signal Light (RSL) displays. A mentor on our team found the following from Team 358 (thanks!): Quote:
I also found this: http://kamocat.com/robot/electrical.php but it doesn't have a date on it (I think it's from 2010). Since it can change every year, does anyone know a source for this year's info? A link, reference to a manual, or simple cut&paste would be appreciated. I've done some searches on CD, but didn't find what I was looking for. Surprising; maybe I didn't use the right search terms. Last edited by Cal578 : 21-02-2012 at 13:18. Reason: fixed an inaccuracy |
Re: Robot Signal Light Patterns
We haven't updated kamocat.com lately. The newest info may be found here.http://www.ti.com/lit/ug/spmu046b/spmu046b.pdf
I don't think the RSL patterns have, or will ever change for as long as that light has been and will be used.
If the patterns have never changed, then I would happily use an older table. Hasn't it been officially documented somewhere? |
It was documented in less detail (only lists four states) in 2009 on the NI "FIRST community" forum:
Nate beat me to it but the flash pattern has been changed since 2009:
And of course if the light is off completely either the cRIO could still be booting or the light may be wired wrong. If the RSL has a different flash pattern that the LED on the Digital Side Car, make sure there is a jumper between La and Lb on the light. Last edited by kjohnson : 24-02-2012 at 09:29. Reason: Nate is obviously quicker than me |
#7
Thanks so much, Nate and Kyle. A forum post isn't quite as "official" as I would have hoped, but I can use it. And I bet other people will, too.
#8
I stand corrected.
#9
I've always had a hard time telling some of those patterns apart at a glance.
I wish some of the errors could be something that stands out more, like a group of short flashes then a long off. You could actually count the flashes and know that something like a group of 3 flashes is no radio comms for example. Also, which one of these patterns is the one we're looking for to be ready to start a match? I'm assuming the slow blink (900ms on/off) is Disabled before the match starts. Like I said, they all look the same to me. Good thing I'm not a FTA. |
