Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 21-02-2012, 13:21
Jurrian Jurrian is offline
FRC #3321
Jurrian is an unknown quantity at this point
Re: Programming Pneumatics
Originally Posted by Mark McLeod View Post
For the solenoid/trigger part you need something like the following:
You'll find the solenoid vi's in: WPI Robotics Library->Actuators->Solenoid
The blue "Forward" and "Reverse" you get by positioning the cursor over the input node on the left side of the Solenoid Set vi, right-click to get the node menu and choose Create -> Constant.
Break the wire holding it to the Solenoid Set and copy and paste it wherever it needs to be, then wire them to the proper spots.
This so far not working for our robot. Any other suggestions please?!
