Go to Post Any FIRST pit is my favorite because that means I'm enjoying a FIRST competition so I'm just plain happy anyways. - Koko Ed [more]
Unread 21-02-2012, 11:50
Andrew Lawrence
Posts: n/a
Team 256 presents: LeROY
After 6 weeks of hard work and doing the math, Team 256 has completed its robot for the 2012 season.
Unveil video here.
Yes, we do have bumpers. They weren't on at the time of filming.
Robot Specs:
-Speed of 9.27 fps
-Can score on top and middle hoops, though has a preference for middle hoops
-50" tall, 27"x37" wide frame
-4, 4" plaction wheels spread for optimal sturdiness and bridge balance
-"Finger" ball intake allows ball pick up from either side, at any speed
-Polycord ball elevator allows for storage of up to 3 balls
-2 wheeled shooter powered by Banebots 775's makes full court shots
-Articulating shooter can change the angle of the shot anywhere from vertical to horizontal
-Bridge manipulator allows for quick bridge actuation and crossing
-Wide robot configuration makes optimal bridge balancing with other robots
For more information, go to wghsrobotics.webs.com.
Enjoy!
Unread 21-02-2012, 12:21
Greg Leighton's Avatar
Greg Leighton Greg Leighton is offline
FRC #2337 (EngiNERDs)
Greg Leighton is an unknown quantity at this point
Re: Team 256 presents: LeROY
Originally Posted by SuperNerd256 View Post
-"Finger" ball intake allows ball pick up from any side, at any speed
Enjoy!
Do you mean either side? It appears you have an opening for ball intake on what would be the front and back of the bot but not on the right and left side. And if you could, describe the functionality of this "finger" intake, couldn't watch the video at the moment.
Good is the enemy of Great
Unread 21-02-2012, 12:24
Andrew Lawrence
Posts: n/a
They are multiple hose pieces curled a bit inwards. They allow us to pick up balls no matter what speed they come in.
I changed it to either. Thanks for the heads up!
Unread 21-02-2012, 12:31
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Which motor did you use for the bridge controller?
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 21-02-2012, 12:36
Andrew Lawrence
Posts: n/a
I think it's a window motor. I'll ask our mechanical captain for clarification.
Unread 21-02-2012, 13:27
Andrew Lawrence
Posts: n/a
I was wrong. It's a Van Door motor, geared for the maximum amount of torque possible. Hope that helps!
Unread 21-02-2012, 13:34
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Looks good I'll make sure to keep an eye out for it on the webcasts. I'm digging the halo music too.
Unread 21-02-2012, 13:41
Djur's Avatar
WPILib
AKA: Sam Carlberg
Thanks! We're currently using a window motor and it's just too weak to be able to do what we want
