Go to Post Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. - Billfred [more]
Unread 21-02-2012, 13:51
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Team 578 Presents Darth Raider
Here is the Robot unveil http://www.youtube.com/watch?feature...&v=N0im0XImxBg
Shooter:
  • Powered by 2 fisherprice 9015 motors.
  • Has a Max Distance of about 30 Feet.
  • Once we put on our 0673 motors it will shoot farther.
  • The Angle of the shooter can be manually adjusted before the start of the match.
  • Rotation of about 270 degrees
  • Rotation is powered by a andymark 9014 motor.
  • The shooter uses the camera for assisted aiming of the shooter.
Wedge:
  • Wedge powered by 1 window motor
Lift and intake roller:
  • Lift powered by a denso throttle control motor
  • The lift uses poly-cord to carry the ball resting on a series of PVC rollers.
Drive Train:
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-02-2012, 13:57
Andrew Lawrence
Posts: n/a
Re: Team 578 Presents Darth Raider
Awesome robot! Any video of the wedge in action?
Unread 21-02-2012, 14:15
stundt1's Avatar
Steve
I forgot to add the total weight is around 118-120 pounds.
Any questions?
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-02-2012, 19:40
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Awesome Robot!
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 21-02-2012, 20:26
stundt1's Avatar
Steve
Here is some CAD renders. This is our first year doing CAD and it really helped out.
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-02-2012, 21:53
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Ryan_Davis is an unknown quantity at this point
Look forward to competing with you . Well done!
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 21-02-2012, 22:09
stundt1's Avatar
Steve
You too good luck. Maybe we will play together like in 2010
Steve
-Programming Mentor
- Team 578 Alumni
