Go to Post I'd rather have our robot not fall over. - Andy Baker [more]
Unread 21-02-2012, 14:06
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
how to stop a compessor when disabled
how would you stop the compressor when teleop is disabled. I tried putting a compressor stop under disable, but it doesn't restart.
Unread 21-02-2012, 14:08
Re: how to stop a compessor when disabled
All of your outputs will be disabled automatically when the robot is disabled, no need to add any code to disable the compressor.
Unread 21-02-2012, 14:20
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
but it doesn't. do you think it is electrical and not programming?
Unread 21-02-2012, 14:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It could be wired wrong. How does the compressor get power?
Unread 21-02-2012, 15:40
Is the pressure switch wired in series with the compressor? It needs to be fed through the DSC to a Spike. The Spike is disabled by the Crio when the rest of the robot is disabled.
Unread 21-02-2012, 16:34
Originally Posted by Vikesrock View Post
A bad DSC is the only thing I have seen that can cause relays to keep running when the robot is in Disabled mode.
Connecting a Spike's control input to a general purpose digital output instead of the proper relay pins can do it too.
