Motor speed/blowing up
Has anyone had problems with any banbots 550 motors blowing up when u lower the speed in the programming.
Re: Motor speed/blowing up
Seriously, if you want useful answers, you need to post useful information, such as: - what is the motor driving? - what is the gear ratio from the motor to the driven device? - if the driven device is an arm of some sort, do you have an estimate of the torque load on it ? - what was the %PWM command when this happened? how fast was the driven device moving (turning) when the motor "blew up"? - Jag or Vic ? - are the 550's air vents properly vented? - anything else pertinent that you can think of |
Plus:
Speeds Load Current readings... We'll help, but only if we have some clues. |
