Go to Post It kicked off today, and we already have 10 pages of posts!?!?! - ShotgunNinja [more]
Unread 21-02-2012, 10:00
akmess01's Avatar
akmess01 akmess01 is offline
FRC #3824 (RoHAWKtics)
akmess01 is an unknown quantity at this point
Bumper Brackets
Can the brackets that attach to the bumpers extend past the bumper zone. The bumpers are still in the bumper zone, but part that attaches the bumpers to the robot extends out of the zone. Is this legal?
Unread 21-02-2012, 10:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper Brackets
Pictures?
If the bracket is part of the robot frame (not part of the bumper), and extends above 10" or below 2", it should be fine. The bumpers themselves need to be within the bumper zone.
Unread 21-02-2012, 10:14
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Bumper Brackets
If the brackets you are referring to are permanently part of the bumper, then the answer is "No". Everything that attaches to the main bumper is part of the bumper.
[R29] says:
Bumpers must be located entirely within the Bumper Zone when the Robot is standing normally on a flat floor.
(emphasis added)
Also, [R33] says:
Bumpers must be supported by the structure/frame of the Robot (i.e. each end of the Bumper must be rigidly attached to the Frame Perimeter, ...
so I'm not sure why you would want your brackets extending outside the zone.
A picture would probably help us answer your question more directly.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 21-02-2012, 10:27
Re: Bumper Brackets
As I interpret your question, the brackets would legally need to be part of the robot frame, and must therefore fit inside the sizing box and would then also establish the frame perimeter.
Unread 21-02-2012, 11:18
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Bumper Brackets
Making an exterior vertex & requiring 8" of bumper on either side? (assuming they poke out from the frame.)
Unread 21-02-2012, 11:22
akmess01's Avatar
Re: Bumper Brackets
Here is a picture
Unread 21-02-2012, 11:30
Re: Bumper Brackets
If that's above 10", then you'll need to trim it down. Bumpers need to be within the bumper zone (and attachments on the bumper side are part of the bumper).
I'd also think about using somewhat heftier screws; the ones you have on there are looking like they might be a little on the non-durable side.
Unread 21-02-2012, 12:51
Re: Bumper Brackets
I agree that the top of the strip needs to be under 10" above the floor. The frame perimeter is set (theoretically) by wrapping a string around the frame within the bumper zone. It may not produce a vertex but it does set the outer limit of the frame perimeter plane and it must not exceed the maximum robot dimension as judged by the sizing box.
Unread 21-02-2012, 15:34
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Bumper Brackets
Originally Posted by akmess01 View Post
Here is a picture
I'd suggest protecting that cRIO a bit more than shown. Usually you want the cRIO in a location that minimizes the likely hood of damage... I can easily see another bot's bridge tipper or falling robot doing some serious damage to it where you have it now.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
