Go to Post Yes, a good driver can effectively be the element that closes the loop, but only when there is a driver at the controls. - Alan Anderson [more]
Unread 21-02-2012, 13:01
ianschofield's Avatar
ianschofield ianschofield is offline
ianschofield is an unknown quantity at this point
Ball Kicker
Hi All
Joe public here, Has any teem conceded using a kicker to kick ball from the opponents side of the field
Back in to your side when you are full load ??????
Good Look to you all
Unread 21-02-2012, 15:28
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Ball Kicker
Originally Posted by ianschofield View Post
Hi All
I suspect that would be considered 'controlling' four balls.
Also, implementing a kicker for use only when you have three balls on board takes a fair bit of extra resource (design time, weight, physical space, etc.)
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 21-02-2012, 15:35
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Re: Ball Kicker
I do not think that many teams are going to use a kicker, but I would not be suprised if a team with a strong shooter will try to shoot from the other zone or tries to just eliminate the other alliances's offensive strength. In other words a team with a strong offensive bot could also in this game be a strong defensive bot as well.
Hope everyone had a good build season and good luck at the competitions.
Unread 21-02-2012, 15:39
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Ball Kicker
Correct.
G22:
Robots may only actively control three Basketballs at any time.
Violation: Foul per extra Basketball
Moving or positioning a Basketball to gain advantage is considered actively controlling. Examples are “carrying” (holding Basketballs in the Robot), “herding” (intentionally pushing or impelling Basketballs to a desired location or direction) and “trapping” (pressing one or more Basketballs against a Court element in an attempt to shield them).
Also correct—no further support needed here.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 22-02-2012, 10:47
Re: Ball Kicker
Originally Posted by Duke461 View Post
Correct.
G22:
Well spoted Duke461 I must get back to the rules.
Good luck to you all.
