Go to Post I thought of this at least a couple of years ago, but I didn't post because I didn't want to give Dave any fiendish ideas. He has enough without our help. - ChrisH [more]
Unread 04-01-2003, 22:17
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Rule M17
Rule M17 states that "Traction devices may not have surface features such as metal or hard plastic studs, cleats or other attachments. <NOTE HERE TO TEAMS!!!> The outer surface of off-the-shelf wheels may be modified by REMOVING TREAD MATERIAL ONLY." so it is now illegal to wrap the wheelchair wheels with anything?
Note that later on (additional materials list) it makes references to being able to put belts on wheels, and that belts used for traction don't count as belts for cost purposes.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 05-01-2003, 12:46
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
Belt aren't metal or hard plastic, are they? A good judge i think would be if it penetrated the metal mesh ramp: they said we couldn't do this at all. Otherwise, i think it would be okay....
lauren
Unread 05-01-2003, 13:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Look at the Restricted Parts List. It says you can use any belt from anywhere as a traction device.
Unread 05-01-2003, 14:07
Hawk135 Hawk135 is offline
#0805 (Igniters)
Hawk135 is an unknown quantity at this point
Send a message via AIM to Hawk135
So does anyone know if it is within the reason of the rules for my team to cast themselves some rubber treads?
Unread 05-01-2003, 14:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I dont know why you would want to do that... Just buy some from Breco-Flex, McMaster Carr, or MSC. They have any combination of size/width/material that you could ever want.
2001-2004: Team 100
2006-Present: Team 254
Unread 05-01-2003, 15:24
The big guy
What I was refering to was that altho it stated that you may use belt for a traction device, by the wording of the other rules you cannot attach it to off the shelf wheels. Or modify off theshelf wheels other than cutting tread into them.
Justin Stiltner
KI4URQ
Unread 06-01-2003, 19:03
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
Breco Flex makes very high quality belts - very expensive, but apparently worth the money - very, very high quality belts.
Benjamin Mitchell
Vex Robotics Competition team advisor (4 high school teams)
Unread 08-01-2003, 02:19
Caroline Caroline is offline
#0192 (Gunn Robotics Team)
Caroline has a spectacular aura aboutCaroline has a spectacular aura about
Send a message via AIM to Caroline
Re: Rule M17
I interpreted that in the same way you did. Since attaching tread is NOT removing tread, it is illegal to do on off the shelf wheels.
My Favorite rule. :) Useless member Rules/Strategy 15 01-03-2003 00:44
Proposed New Rule M11 Joe Johnson Rules/Strategy 14 04-02-2003 14:41
Adhesive, Brecoflex, Rubber, and M17 Madison Technical Discussion 14 09-01-2003 10:57
Rule C1 Justin Stiltner Rules/Strategy 9 05-01-2003 22:59
1 coach rule Mike Soukup Rules/Strategy 14 07-01-2002 22:27
