Go to Post Everyone please breathe before you post. - Jessica Boucher [more]
Unread 21-02-2012, 16:33
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Our Robot weight woes.. to rebuild or not to rebuild
As mentioned in this thread http://www.chiefdelphi.com/forums/sh...=102188&page=5
Our robot when we just weighed it was ~148 lbs (without bumpers and battery)
We are trying to see where to take all the weight off but we just cant see how to while keeping structural integrity (see robot below)
So out question is, what if we did something crazy! such as make a new robot!?!
out shooter works great so if we kept that and rebuilt everything else could we manage in ~9.5 hours?
Thought? Plans? Suggestions?
Thanks,
2240
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 21-02-2012, 16:34
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Our Robot weight woes.. to rebuild or not to rebuild
You want to rebuild a robot and integrate a functional system into it in 9.5 hours?
I don't understand where you're getting the majority of your weight from. It appears to be quite a small, compact little bot. How much does your drive train and shooting mechanism weigh?
Unread 21-02-2012, 16:38
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Hmmm - it does not look crazy heavy. Are you sure your scale is accurate?
Are those plates on top solid material? Do they need to be?
Are the vertical support pieces solid? Will lighter extrusion work?
What are the red things in the middle?
Is there any steel on the robot? Can you substitute aluminum of similar dimensions?
Unread 21-02-2012, 16:40
Andrew Lawrence
Posts: n/a
For starters: Wheels
Those pneumatics look kinda heavy to me, so maybe switch them out for 8" plaction wheels, or maybe even 6" ones. You should be able to get away with going over the bump with them.
If you're really pressed for weight, and want a competable robot, I'd put serious thought into not going over the bump at all. Take out the lift kits, and replace the pneumatic wheels with smaller, light ones. Re-organize your strategy to work on one side of the field. There are so many successful strategies using only one side of the field, and that could be a major benefit to you (PM me for examples of such strategies, we can talk).
That's a nice turret you have there. Take it off. A stationary shooter has worked extremely well for us, and from what we've seen at our practice day worked way better than the turreted ones.
Like said above, double, if not triple check your weight. You don't look heavy, but if you are, these are some steps to follow.
AKA: Bryan
we aren't really sure where all the weight is coming from.. we think its the motors and electronics
4 CIMs
2 window
2 throttle
3 Banebot775
plus the electronics
cRio2
6 Jags
3 victor
2 spikes
Kinect
small laptop (for image processing
plus the 4 andymark pneumatic tires
Unread 21-02-2012, 16:44
Andrew Lawrence
Posts: n/a
4 CIMs
2 window
2 throttle
3 Banebot775
cRio2
6 Jags
3 victor
2 spikes
Kinect
Weigh the laptop and kinect together and see what they weigh. We have more electronics and motors than you, yet we still aren't that heavy.
AKA: Bryan
We took it to the local PetsMart scale so its fairly accurate
Yes solid 1/8 Aluminum, maybe not
No they are 1x2 Aluminum extrusions, possibly switch to 1x1
they are 8in concrete cardboard tubes used to hold the balls once they are captured
nope, all Aluminum, the only steel is the 2 3/8in rods on the shooter
Last edited by viperred396 : 21-02-2012 at 17:04. Reason: Changed 1/4 in AL to 1/8 in AL for top and bottom plate
Unread 21-02-2012, 16:47
FRC #0023 (PNTA)
Rookie Year: 1620
I laughed at that
SuperNerd has some pretty good ideas. I'd also consider swiss-cheesing your top aluminum plate, if not replacing it with polycarb/plywood. The polycarb would look wicked nice, but plywood weighs less.
Take a look at the on-board computer you've got. Can you strip any parts off of it or replace it's battery with a smaller one?
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
How thick is the metal you are using? 1/16th inch is often plenty and half the weight of 1/8. Also solid plates are usually over kill, we saved like nearly 2 lbs by pocketing out a a 17inch circle of alum.
You could swap to 6inch wheels [loose some bump abilities...] and save some weight off those pneumatic tires.
And as said above check to see if your scales are correct, weigh a person who knows there weight[safety first though] to see if it is off.
This late in the game rebuilding large portions of your robot is probably to late... best try finding parts you can swap or take off. Large pieces of metal are a good place to start. Figure out what needs strength and what doesn't. And don't be afraid to loose some functionality. Lesser under weight robot is always better than a over weight robot of any caliber.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 21-02-2012, 16:52
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
We were worried about weight on our robot so we dropped the thickness of the sheetmetal we were using in a lot of places; or you could switch to plastic all together. Not only is the thinner stuff lighter but its way easier to machine and cut. Also what size bolts are you using, we dropped ours down to #10-32 to just about everything and saved a ton of weight.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Welcome to the wonderful world of weight loss! We recommend that you weigh in early and often so you won't come back to visit next season.
Unless you know where all that extra weight is coming from, building an entirely new robot in 9.5 hours isn't going to save you. You're just as likely to end up with a second overweight robot. If you DO know where all the extra weight is coming from, then you should be looking at removing those systems/parts to make your weight.
Looking at your picture, it's difficult to see where all of that weight is actually coming from. Until you can provide more and closer pictures of the robot, I'll throw out some general purpose weight loss guidelines:
  1. Steel is heavy. Anywhere there's steel on your robot is a place to reduce weight by removing it or replacing it with Aluminum.
  2. Flat sheet and plate are heavier than thinner sheet and plate with a tube supporting it. Look for large expanses of thick plate material and see if you can replace it with thinner material with a tube or beam supporting it. (I'm looking at that Lexan electronics board).
  3. Motors are heavy. If you're using a bigger motor than you need for a task, look at swapping in a smaller, lighter one.
  4. Pneumatics can be heavy. If you're using pneumatics, make sure you're using the lighest, smallest cylinders possible, and look at using plastic air tanks and keeping the compressor off-board.
  5. Subsystems are heavy. Seeing as how a subsystem is guaranteed to have a combination of all of the above, subsystems are very heavy. The absolute quickest way to lose weight and become legal is to ditch an entire subsystem. Which system you ditch would depend on your priorities and the relative weights of the systems. Offhand, I would suggest that a turret on an overweight robot is about as useful as a bicycle for a fish. If I could ditch everything for the turret and have a fixed shooter on a legal robot, I would do that in a heartbeat.
Unread 21-02-2012, 16:59
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
by observation, it would appear you have a thick electronics board. Also, you have some sort of metal sheet across the top. Pair it with w/e those giant red things are.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 21-02-2012, 17:07
AKA: Bryan
Thanks all for the quick and helpful replies!
Here are alot more pics from all round the machine b/c you asked
Also those red tubes are just 8in Carboard tubes used to hold the ball after it is picked up
http://img825.imageshack.us/slidesho...img0251njz.jpg
Unread 21-02-2012, 17:17
Tylernol's Avatar
Tylernol Tylernol is offline
FRC #2993 (MegaBots)
Team Role: Marketing
Tylernol is an unknown quantity at this point
From what I saw in the images you posted, there were a lot of flat metal areas without anything mounted on them. You could probably swiss cheese them a bit and lose some there.
Unread 21-02-2012, 17:18
FRC #0023 (PNTA)
Rookie Year: 1620
Time to break out the 5'' drill bit!
If you have your heart set on a turret, replace that aluminum plate with polycarb - that'll save you quite a few pounds. To go further, swiss-cheese the polycarb.
Now, the plate/sheeting down below your construction cardboard can be cut and/or swiss-cheesed.
The metal plate off to the right side of picture 3 looks AWFULLY thick. Does it need to be this thick and made out of metal?
The swinging metal door you've got can go. Replace it with netting and a few staples.
That laptop....do you REALLY need a screen? Remove it and use the VGA/HDMI port when you need to service it.
Your electronics board is quite thick. Replace it with thinner plywood.
Your wheel lift kit looks pretty heavy. Swiss-cheese it.
Go crazy with hole-drilling. Also, drop some of your hardware sizes to 10-32 if you can.
Drill your aluminum support pieces
I believe Victors weigh less than Jags. If you're not using CAN, I would weigh your Jags and see if it's worth swapping some/all out for Vics.
Back to the laptop, it looks big and heavy. I'd really consider removing the screen, and depending on how much hard drive space you need, using a lighter SSD, or creating your own SSD by buying a bunch of cheap flash drives, gutting them and arranging them all into a USB hub(s). From there, install whatever OS you want and arrange your drives into a RAID array if you want only one drive letter, as opposed to 10.
Remove the CD tray, and CHANGE THE BATTERY out for a smaller one!
