Go to Post You know you have FIRST Kickoff fever when you know when Kickoff is but not Christmas. - Jacob.B [more]
Unread 21-02-2012, 16:40
Andrew Lawrence
Posts: n/a
Re: Our Robot weight woes.. to rebuild or not to rebuild
For starters: Wheels
Those pneumatics look kinda heavy to me, so maybe switch them out for 8" plaction wheels, or maybe even 6" ones. You should be able to get away with going over the bump with them.
If you're really pressed for weight, and want a competable robot, I'd put serious thought into not going over the bump at all. Take out the lift kits, and replace the pneumatic wheels with smaller, light ones. Re-organize your strategy to work on one side of the field. There are so many successful strategies using only one side of the field, and that could be a major benefit to you (PM me for examples of such strategies, we can talk).
That's a nice turret you have there. Take it off. A stationary shooter has worked extremely well for us, and from what we've seen at our practice day worked way better than the turreted ones.
Like said above, double, if not triple check your weight. You don't look heavy, but if you are, these are some steps to follow.
Unread 21-02-2012, 16:47
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
I laughed at that
SuperNerd has some pretty good ideas. I'd also consider swiss-cheesing your top aluminum plate, if not replacing it with polycarb/plywood. The polycarb would look wicked nice, but plywood weighs less.
Take a look at the on-board computer you've got. Can you strip any parts off of it or replace it's battery with a smaller one?
Unread 21-02-2012, 16:52
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
We were worried about weight on our robot so we dropped the thickness of the sheetmetal we were using in a lot of places; or you could switch to plastic all together. Not only is the thinner stuff lighter but its way easier to machine and cut. Also what size bolts are you using, we dropped ours down to #10-32 to just about everything and saved a ton of weight.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 21-02-2012, 19:15
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by DominickC View Post
I laughed at that
Swiss-cheese that top plate, reasonable-thickness polycarb won't support that shooter.
