Go to Post Who am I kidding, FIRST is so much cooler now than it was when I was a youngin'! - Michael Corsetto [more]
Unread 21-02-2012, 17:27
Re: Adding a delay to commands
Originally Posted by APrettyDucky View Post
What I need to do is figure out how to add a delay to a command, like when i press and hold button, the motor that is supposed to turn is delayed for a second, and then turns. I am also wondering how to implement this into autonomous.
Thanks
You have two choices:
1) state machine
2) periodic tasks
Unread 23-02-2012, 21:48
kentwedeking's Avatar
kentwedeking kentwedeking is offline
LabVIEW Zealot
FRC #0967
kentwedeking is on a distinguished road
Set a flag that you've pressed a button via a functional global or using a global variable and put your sequence code in the Periodic Tasks VI. If you leave it in your Teleop or autonomous you'll not be happy ... it'll block your execution and cause you code to have delays you don't want ...
