Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 21-02-2012, 19:33
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Can't install FRC Driver Station Update 2012
We installed the DS Update from [1], and it appears to install fine. Everything goes, the installer says it's finished, and we reboot the computer. However, when we turn the driver station back on, the DS revision number is only 11.30.11.00. The inspection sheet says that the Revision must be at least 01.07.12.00 or newer. I have installed and reinstalled the update at least 3 times. I have redownloaded the file. The file was posted on the 7th, so it doesn't seem like I have the wrong file. Anyone know what's going on?
[1] http://joule.ni.com/nidu/cds/view/p/id/2263
Unread 21-02-2012, 19:37
Re: Can't install FRC Driver Station Update 2012
Looks like the Inspection Checklist is wrong, R80 specifies 11.30.11.00
Unread 21-02-2012, 20:01
Could they have changed it when they released the inspection checklist and neglected to change the rules listing?
Unread 21-02-2012, 20:02
The rule was fixed in a Team Update so I'm guessing it's the checklist that's wrong.
Unread 24-02-2012, 15:22
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Question Re: Can't install FRC Driver Station Update 2012
I have seen the same phenomenon, i.e. downloaded and installed update but the version number does not change. I also agree that the update to R80 should correct this. However, not all inspectors are experts in the details rules. It would be good to have this resolved long before the first competition.
Has anyone posted this as a Q&A question?
Unread 29-02-2012, 15:49
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Talking Re: Can't install FRC Driver Station Update 2012
For anyone who didn't see the update to the Inspection Checklist, this version number has been corrected.
