Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 21-02-2012, 20:22
Re: rpm from encoder
Originally Posted by Brandon_L View Post
Were getting the rate from the get VI but that doesn't help, unless you can convert it somehow which were at a loss for
That rate is in pulse per second (if your distance per tick is set to the default of 1). You should be able to convert that to RPM by knowing how many pulses per rev for your encoder.
Unread 22-02-2012, 12:21
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
We converted it into rpm, but what should be a good time in ms to set the timer config in the begin too? Our indicator is twitching around so much we can't really read it
Unread 22-02-2012, 14:22
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
We are using DMA to read our encoders. Check out the DMA-Encoder example to implement this
Unread 22-02-2012, 23:55
linked for readers:
http://www.chiefdelphi.com/forums/sh...16#post1133016
