Go to Post What has happened has happened. Humans were involved, mistakes made. Clarification will come... - Wetzel [more]
Unread 21-02-2012, 20:42
jaysun jaysun is offline
jaysun is an unknown quantity at this point
Consistent encoder rate
Hi,
Our team is having trouble getting a consistent rate value from one of the optical encoders. The Rate value jumps around a lot, even when we use 1x decoding and choose to average 127 samples. When we made our own rate code based on the encoder's Distance, the variance persisted. It really messes with our PID loop when it tries to keep the speed of the motor consistent. (Note: the jumpiness occurs when the PID loop is not controlling the speed of the motor, so the problem is not caused by the PID controller.)
Any idea what the problem could be and how to fix it?
Thanks for any advice.
Unread 21-02-2012, 22:00
Re: Consistent encoder rate
Originally Posted by jaysun View Post
Hi,
What is the encoder brand and model number ?
If you rotate it slowly by hand and read the encoder counts, do you get consistent results for each rev of the shaft?
Check to make sure the optical disk is properly mounted to the shaft.
Unread 21-02-2012, 22:13
We use this. Tomorrow I will make sure the optical disk is properly mounted to the shaft and I will rotate the shaft slowly by hand and read the encoder counts and I'll let you know if I get consistent results for each revolution of the shaft.
Unread 21-02-2012, 22:28
Look at the 2:15 minute mark of this video:
http://www.youtube.com/watch?v=4hJfzhxZwKw
Unread 22-02-2012, 16:25
Since I forgot my team is not meeting until next Tuesday, I will check it then.
Averaging the rate further with a moving average gives us a mostly constant speed (+-2%), but the problem is that when the PID loop adjusts the motor speed, it will oscillate the motors because the "moving-averaged" process variable that the PID uses does not accurately reflect the present rate of the motor. Would applying any of the filters described in this thread give us a smoothed rate that more accurately reflects the present speed of the motor?
Unread 28-02-2012, 19:23
No luck. We have decided to look into testing the magnetic encoder from the KOP on a test motor.
Unread 28-02-2012, 20:48
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
How did this work out?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 28-02-2012, 20:56
Like so:
Unread 28-02-2012, 21:55
slijin's Avatar
Pockets
AKA: Samuel Lijin
Like so:
I wanted him to clarify whether that post was pertinent to the attempt at filters or rotating by hand. I should've been more clear on that point.
Unread 28-02-2012, 22:15
I tightened the encoder discs on the axle as shown in the video, and I made sure there wasn't any slipping. When I rotated the encoders by hand, the Distance count was kind of consistent: I'd say about +-10 counts.
I tested an IIR filter of the encoder speed and compared it to a moving average. You can see an example of my results in this video. The problem with the PID loop adjusting the speed is still present. I'm still not sure if there is a good filter or not.
Unread 28-02-2012, 22:34
slijin's Avatar
Pockets
AKA: Samuel Lijin
That's an extraordinarily noisy signal. Is the green the moving average and the red the IIR? Also, just out of curiosity: how are you obtaining the encoder input, through a Jaguar or the DSC?
I don't know about you, but we ran into issues with scratched encoder wheels and damaged encoder wires (there was no visible damage; I assume it was internal from abusive zip-tying, but swapping out the wire resolved the issue).
A bit of advice I've been given by my mentor (although I've never personally experienced this problem) is to always separate signal runs from power runs so that the power runs don't induce noise in the signal; if they have to cross, run them at right angles. Ether would be able to elaborate more on this.
Unread 28-02-2012, 22:58
I should clarify my last post and note that my video was not based off my actual data. I generated the "measurement" (green line) by adding a random number to the rate I set - in reality the "amplitude" of the noise is about half of that. The red line is the IIR, and the blue line is the moving average.
With the optical encoder I use the DSC.
Yes, I made sure the encoder wheels were not scratched - I scratched a lot of them when we first started using them last year. We did twist the encoder wires with a hand drill to make the wiring look good - maybe that's a problem?
Thanks for the ideas. I'll try to use a new, different encoder cable and separate the power and data wires and see if the rate I get is any less noisy.
Unread 28-02-2012, 23:55
Here are a couple other things to consider:
+-10 out of how many? and roughly how accurately did you rotate it (i.e. by "eye" or did you make a mark etc)
127 samples at 20ms per sample? That's 2½ seconds. That's not what you meant is it?
This doesn't sound right. Would you mind describing exactly what you did?
- 1x or 4x?
- Counter class or Encoder class or something else?
- sample time? how controlled? measured or assumed?
- did your code look like this: read count, subtract previous count, divide by measured elapsed time since previous sample?
Unread 29-02-2012, 00:13
slijin's Avatar
Pockets
AKA: Samuel Lijin
Twisting the wires like that is some serious abuse; you're placing a lot of tension on a solid length of copper. Wire may flex, but spinning it is asking for trouble. If anything, braid the wires.
To clarify, I don't mean separating the power and data lines coming from the encoder; I meant separating all 4 encoder lines (+5, A, B, GND) from the power lines going to the motor. Ether, could you comment on how recognizable this effect would be?
Unread 29-02-2012, 00:30
I don't have any pertinent test data. It would make a good project. Put a scope on an encoder signal wire and observe the noise when it's routed near motor wires. Has anybody done this and have data to share?
