Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 21-02-2012, 22:14
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: paper: How to Get Multiple Cameras on Robot
We have been using another 12V-5V Power Converter to power our Axis M1011 camera and notice the camera reboots after 3-4 minutes of heavy robot use (i.e. running 2 practice matches). Anybody else seeing that issue? We may try running it off the 5V Wago supply if people indicate that it works well.
Unread 22-02-2012, 17:20
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
3-4 minutes of heavy robot use would tend to draw down your battery below 7 volts, which would cause the converter to stop functioning.
Unread 23-02-2012, 19:04
DavidGitz's Avatar
Maybe it's too late for me, but with this line of logic wouldn't the robot radio be rebooting as well? Since it is not, I don't necessarily agree with this. And isn't that the point of the 12V-5V Converter anyways?
Unread 23-02-2012, 22:45
The 12V-to-5V converter for the DAP-1522 is connected to an up-regulated 12 volt output. It won't drop out until the robot battery goes very low, about 4.5 volts.
Unread 24-02-2012, 22:52
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Have we decided whether or not a judge would get freaked out by the 5volt regulated power feeding both cameras?
Unread 25-02-2012, 00:17
Why would a judge care?
If you're talking about whether it would pass inspection, I know of no rule that would get in the way.
Unread 02-04-2012, 17:46
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
I can confirm that this works. You can run two axis cameras from the PD board without any issues. Also for reference, a single camera draws about 250mA under normal use, so you're well under spec there even with two cameras!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 03-04-2012, 19:44
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Thank you very much for posting this document. I had one question. You guys showed how to edit the dashboard code, which I followed easily. However, I would assume you would have to edit the robot code too, right? Would you just copy the code for the first camera to add the second?
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 03-04-2012, 19:52
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Easy if you use USB webcams like we did with a laptop on the robot.
You can easily put 2 webcams on a laptop, sometimes 3 (depends really on the number of root hubs in the laptop, most netbooks have 3 USB ports but only 2 root hubs).
If you use a MultiTT USB hub you can usually get to 3.
We can confirm that putting a laptop within the rule restrictions is allowed and has passed inspection at 3 competitions.
It's quite cost effective as well. Consider how much 3 of those Axis cameras would cost versus the $25 webcams.
You can get 1080P webcams now. Think about what you could do what that sort of resolution. Think about what you could do with 45-50 frames a second from some webcams at 640x480.
Unread 04-04-2012, 01:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
This whitepaper is documenting how to attach a second camera and add it to the driverstation display. In this game, likely as a POV camera for ball hunting. As described in the whitepaper, this takes about 30 minutes or less of programming, and no particular expertise.
So I fail to see how adding an entire laptop with USB cameras is a more economical solution to this problem. (Axis cameras are about $125, by the way. Is that a $200 laptop?) And then there's the complication of the custom code on your laptop and interfacing that to the code on the driverstation to display the video from the cameras.
So, while a secondary laptop for image processing is a nifty idea, I don't think it has any relevance whatsoever to this (rather good) whitepaper.
Unread 04-04-2012, 01:35
BHOP BHOP is offline
FRC #0399 (Eagle Robotics)
BHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud of
We had a slight problem with this at the Colorado regional. The tutorial was excellent and we got the second camera up in like you said 30 mins.
BUT...
We could not get our ping times on the field low enough to support both cameras together. At the worst we saw pings of 160ms, and at best we saw 30-40ms. The threshold value to be "satisfactory" is 20ms, told to us by the FIRST field staff is where you will not have comm issues. When we operated with one camera we saw 6-8ms with the old axis and 10-20ms with the new axis camera. Together they were 30-40 so that was a no go.
Anyone got any ideas on how to get ping times down with two cameras? we were at the lowest resolution 7fps on both and 75 compression. I couldn't think of anything else. We also found that switching cables and locations helped significantly but not good enough...
we just guessed the field network cannot handle all the video stream we want to put through...
BHOP
ME CoE University of Michigan
503 Frog Force 830 Rat Pack
399 Eagle Robotics
Unread 04-04-2012, 07:36
Dialing down the camera settings should have been good enough. Perhaps your Driver Station computer is being overtaxed by trying to display the images. You can check its CPU usage in the Task Manager.
Unread 04-04-2012, 09:32
techhelpbb's Avatar
3 Axis cameras at $125 each would be $375. I originally wrote:
"Consider how much 3 of those Axis cameras would cost versus the $25 webcams."
However, now that you've stated you've been getting them for $125 each can you tell us how? Last year when we bought them they were at least $150 each.
If you really want to send the video back to the driver's station from a webcam(s) attached to a robot mounted laptop there are quite a few ways to achieve that. Including but not limited to installing VideoLAN and streaming it from the laptop on the robot to the laptop at the driver's station.
Here's an example of how to do it in Linux (which is what the students had on our robot laptop) and even rebroadcast that to the Internet:
http://www.wikihow.com/Stream-Your-Webcam
BTW, this example uses UDP, not TCP, which might actually come in handy if you do start dropping packets.
This method gives you fine control over both ends of the streaming, including the compression methods, transmission protocols, and the communications stacks themselves (for example you can reduce the MTU, you can increase the receive window, etc).
There's no problem with the whitepaper at all it is great work. There is just more than one way to do this and there shouldn't be any problem with mentioning that considering the title of the topic in question is: "How to Get Multiple Cameras on Robot". Consider for archival sake what will happen if someone searches for that later when this topic is less recent.
Sorry if I've ruffled anyone's feathers wasn't my intent.
Unread 05-04-2012, 09:50
techhelpbb's Avatar
A few other things about VideoLAN that might be relevant to using it like this:
Here's a way to overlay something on the video (like the privacy filter on the Axis cameras):
http://www.recipester.org/Recipe:Ove...yer_3 3186770
Here's a way to 'float' the video without the frames in an overlay.
http://vollnixx.wordpress.com/2011/1...rlay-with-vlc/
If you dig around in VideoLAN you'll also find that you can basically control all it's functions remotely from devices that can't even run VideoLAN itself. For example it can run a telnet server you can connect to and issue it directions.
