Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 02-21-2012, 10:14 PM
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: Java Encoder Limitation?
Originally Posted by patrickviolette View Post
use the constructor Encoder(int sourceA, int sourceB, boolean reversed, EncodingType type) and pass in EncodingType.k2X and you can make as many encoders as you want.
Worked! Thanks!
