Go to Post I'm still thinking about the 1114 469 doomsday.. I mean, that alliance has national champion written all over it. - Joel J [more]
Unread 05-01-2003, 13:47
Norm M.'s Avatar
Norm M. Norm M. is offline
Norm M. will become famous soon enough
Milling Aluminum
I have access to a CNC mill at a University, but have not found anyone who really knows much about machining or selecting tools for it.
I would like to mill a series of triangles into 2024-T3 aluminum, 1/4 inch thick. Cut all the way through.
What cutting tool do I buy to make cuts like this. I would guess something like a 1/4" diameter, double ended 4 flute mill. Is there any rule of thumb or common sizes that tend to be more economical, or work better?
The diameter of the mill will affect inside radius at the corners, of course. A larger mill cutter might be stronger, but would have to remove more material. A smaller cutter would remove less material, but at some point becomes fragile.
And of course, there are differnt coatings on the cutters. What would be an appropriate cutter for aluminum?
Finally, what type of surface speed should you start with?
Regards-
Norm
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
SCRRF Machining Classes Redhead Jokes Southern California Regional Robotics Forum 6 15-06-2003 20:36
Van Door Motor archiver 2001 4 24-06-2002 00:00
Motor coupling archiver 2001 19 23-06-2002 23:35
Gear Making Information Alan Ing Technical Discussion 14 29-10-2001 21:08
