Go to Post When a team is composed completely of robot builders and technical people that team cannot exist just like a company cannot exist if it is only made up of engineers. - Garret [more]
Unread 23-01-2012, 22:49
Tungsten Tungsten is offline
FRC #2853
Tungsten is an unknown quantity at this point
"No rule to make target" error
Hello,
We are having severe errors with Windriver. Whenever we compile a program, regardless of whether or not it has any errors in it, the following error message appears:
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: ***No rule to make target 'b'. Stop.
Build Failed in Project 'AxisCamera' (Process Exit Value was 2): 2012-01-23 17:32:33 (Elapsed Time 00:00)
We have tried putting the same code on a different computer, and it builds perfectly fine. We suspect that something is wrong with the directories, but we don't know exactly what is wrong and how to fix it.
Unread 26-01-2012, 06:44
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
Re: "No rule to make target" error
In WindRiver, try deleting your PPC603gnu folder. Then rebuild the project. That usually solves this problem for us.
-Arthur
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
Unread 27-01-2012, 11:11
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
I ran into a similar problem on one of our programming laptops, it wouldn't even compile example code; I'm not sure if it was the exact error your seeing but it was always the same thing. To fix it, I simply reinstalled Windriver (renamed the old windriver directory to something else), it worked after that.
Hope this helps
Unread 21-02-2012, 23:20
prim0rdia1 prim0rdia1 is offline
FRC #1868
prim0rdia1 is an unknown quantity at this point
We have the same error, and considered reinstalling WindRiver, but the problem came back after a few runs. We managed to fix it (for now because I'm not sure if this solution works all the time)
For those who do have this problem and don't want to reinstall WindRiver, you could make a new workspace on WindRiver and import the code back, but into the new workspace. We have tried this, but this only seems to be temporary.
The second thing we did though, is delete the metadata folder. First, close WindRiver (not a good idea to have WindRiver running when you're deleting this folder). This file should be in the workspace folder created when you create the workspace in WindRiver. Once that file is deleted, reopen WindRiver. Note that your projects won't be there anymore (b/c you deleted metadata). Just re-import the code and build, and it should be fine.
Strangely enough, I thought this would work the same way as deleting metadata files when modding Minecraft. Turns out it did.
Unread 22-02-2012, 01:03
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Another solution I've personally used is to do a "clean"... simply go to the project menu and select "Clean..." and clean the project and rebuild. Sometimes Eclipse/Workbench gets confused and needs a swift kick ...
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
