Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 21-02-2012, 23:21
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Robot unveils / unveiling videos 2012
No video, but a nice web page about the robot can be found here. (includes specs and all)
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 21-02-2012, 23:23
Andrew Lawrence
Posts: n/a
Why do you only use 2 CIMs on your drive when the ones on your shooter only go 40 feet? Our shooter is run with two 775's through CIM-U-LATOR gearboxes and we shoot full court, if not farther at full power. It seems like those CIMs may be better used elsewhere (on your drive).
Unread 21-02-2012, 23:26
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Here is the Robot unveil http://www.youtube.com/watch?feature...&v=N0im0XImxBg
Shooter:
Powered by 2 fisherprice 9015 motors.
Has a Max Distance of about 30 Feet.
Once we put on our 0673 motors it will shoot farther.
The Angle of the shooter can be manually adjusted before the start of the match.
Rotation of about 270 degrees
Rotation is powered by a andymark 9014 motor.
The shooter uses the camera for assisted aiming of the shooter.
Wedge:
Wedge powered by 1 window motor
Lift and intake roller:
Lift powered by a denso throttle control motor
The lift uses poly-cord to carry the ball resting on a series of PVC rollers.
Drive Train:
Kitbot on Steroids Modified by using 8 inch wheels instead.
Turns on a dime.
For more information on the kit bot on steroids go to http://www.simbotics.org/resources/kitbot
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-02-2012, 23:37
Was the estimated landing point. Including the bounce we can go ~60 feet.
Unless you mean your robot can shoot all the way to the end of the court without the bounce...
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 21-02-2012, 23:39
Andrew Lawrence
Posts: n/a
We had to lower our shooter power because we were shooting over the field. No bounce.
Unread 21-02-2012, 23:42
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
http://wcfcourier.com/video-cf-robot...9bb2963f4.html
Unread 21-02-2012, 23:52
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
MARS 2614 is proud to present 'Marvin V' also known as 'marVin.'
https://www.facebook.com/photo.php?f...type=1&theater
Specs:
Drive Train
6WD Dropped center
6 Inch rough-top wheels
Driven by internally run belts and pulleys
Modified AM supershifter, geared for 4.5 ft/sec and 17ft/sec.
Automatic shifting based on encoders
Ball Collector
2 Stage polycord lift system
Lower stage and front roller collect balls
Upper stage stores the balls and feeds them into the shooter
IR senors are used to detect the balls and "organize" them within the magazine
Each stage is powered by 1 BB
Shooter
2 Wheel shooter powered by 1 BB
The cowl angle and shooter speed can be adjusted
Can score in 3pt hoop from the fender, the key, and slightly over half court
Work on full auto targeting and autonomous will continue on the practice robot
The shooter is pointed perpendicular to the driving axis to help with lining up for high-accuracy fender shots
Bridge/Barrier
Marvin V can cross the barrier but prefers to use the bridge
Pneumatically actuated bridge tipper
Auto-level using a gyroscope when balancing alone
Miscellaneous
"MARS Probes" to clear balls from under bridges and corners
Low CG
Reversible Bumpers
The pink pool noodles are just safety covers for the roll bars
Just 2 more weeks until Pittsburgh!
