Go to Post "You know you're a robotics kid when you sit on Chief Delphi and hit refresh over and over again waiting for new pictures and videos of other teams" - pwnageNick [more]
Unread 21-02-2012, 23:08
Andrew Lawrence
Posts: n/a
Robot unveils / unveiling videos 2012
To make it easier to find the unveiling videos scattered amongst the many threads here on CD, please post your robot unveilings and unveiling videos on this thread!
Thanks, and I can't wait to see all of the awesome robots!
-Andrew
P.S. I moved this to "General" to allow posting attachments.
Unread 21-02-2012, 23:09
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Robot unveils / unveiling videos 2012
Thank you
Team 461: Rowdy 13
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 21-02-2012, 23:10
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
FIRST Team 1598 -- Team Talon
http://www.youtube.com/watch?v=xkr7RmcGtvo
A full 2:15 to come.
Unread 21-02-2012, 23:13
Andrew Lawrence
Posts: n/a
After 6 weeks of hard work and doing the math, Team 256 has completed its robot for the 2012 season.
Unveil video here.
Robot Specs:
-Speed of 9.27 fps
-Can score on top and middle hoops, though has a preference for middle hoops
-50" tall, 27"x37" wide frame
-4, 4" plaction wheels spread for optimal sturdiness and bridge balance
-"Finger" ball intake allows ball pick up from either side, at any speed
-Polycord ball elevator allows for storage of up to 3 balls
-2 wheeled shooter powered by Banebots 775's makes full court shots
-Articulating shooter can change the angle of the shot anywhere from vertical to horizontal
-Bridge manipulator allows for quick bridge actuation and crossing
-Wide robot configuration makes optimal bridge balancing with other robots
For more information, go to wghsrobotics.webs.com.
Enjoy!
Unread 21-02-2012, 23:21
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
No video, but a nice web page about the robot can be found here. (includes specs and all)
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 21-02-2012, 23:23
Andrew Lawrence
Posts: n/a
Why do you only use 2 CIMs on your drive when the ones on your shooter only go 40 feet? Our shooter is run with two 775's through CIM-U-LATOR gearboxes and we shoot full court, if not farther at full power. It seems like those CIMs may be better used elsewhere (on your drive).
Unread 21-02-2012, 23:26
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Here is the Robot unveil http://www.youtube.com/watch?feature...&v=N0im0XImxBg
Shooter:
Powered by 2 fisherprice 9015 motors.
Has a Max Distance of about 30 Feet.
Once we put on our 0673 motors it will shoot farther.
The Angle of the shooter can be manually adjusted before the start of the match.
Rotation of about 270 degrees
Rotation is powered by a andymark 9014 motor.
The shooter uses the camera for assisted aiming of the shooter.
Wedge:
Wedge powered by 1 window motor
Lift and intake roller:
Lift powered by a denso throttle control motor
The lift uses poly-cord to carry the ball resting on a series of PVC rollers.
Drive Train:
Kitbot on Steroids Modified by using 8 inch wheels instead.
Turns on a dime.
For more information on the kit bot on steroids go to http://www.simbotics.org/resources/kitbot
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-02-2012, 23:27
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Team 2470's Robot
I'll get a better video up in a few
http://www.youtube.com/watch?v=Sj1No...ature=youtu.be
Specs:
26.5" x 34"
Cannon shoots 47' in the air
Cannon shoots 57' after rolling on the the ground
Able to cross and manipulate bridge
Kinect capabilities
Cannon has variable speeds on both top and bottom wheels for spin
Hopper for catching rebounds, shots from teammates and random flying balls
Autonomous that can score 6 or 4 points
Able to score in all baskets
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 21-02-2012, 23:36
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Here is our release video.
http://www.youtube.com/watch?v=7rGb1a9VOvs
Unread 21-02-2012, 23:37
Was the estimated landing point. Including the bounce we can go ~60 feet.
Unless you mean your robot can shoot all the way to the end of the court without the bounce...
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 21-02-2012, 23:39
Andrew Lawrence
Posts: n/a
We had to lower our shooter power because we were shooting over the field. No bounce.
Unread 21-02-2012, 23:42
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
http://wcfcourier.com/video-cf-robot...9bb2963f4.html
Unread 21-02-2012, 23:52
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
MARS 2614 is proud to present 'Marvin V' also known as 'marVin.'
https://www.facebook.com/photo.php?f...type=1&theater
Specs:
Drive Train
6WD Dropped center
6 Inch rough-top wheels
Driven by internally run belts and pulleys
Modified AM supershifter, geared for 4.5 ft/sec and 17ft/sec.
Automatic shifting based on encoders
Ball Collector
2 Stage polycord lift system
Lower stage and front roller collect balls
Upper stage stores the balls and feeds them into the shooter
IR senors are used to detect the balls and "organize" them within the magazine
Each stage is powered by 1 BB
Shooter
2 Wheel shooter powered by 1 BB
The cowl angle and shooter speed can be adjusted
Can score in 3pt hoop from the fender, the key, and slightly over half court
Work on full auto targeting and autonomous will continue on the practice robot
The shooter is pointed perpendicular to the driving axis to help with lining up for high-accuracy fender shots
Bridge/Barrier
Marvin V can cross the barrier but prefers to use the bridge
Pneumatically actuated bridge tipper
Auto-level using a gyroscope when balancing alone
Miscellaneous
"MARS Probes" to clear balls from under bridges and corners
Low CG
Reversible Bumpers
The pink pool noodles are just safety covers for the roll bars
Just 2 more weeks until Pittsburgh!
Unread 21-02-2012, 23:55
HannahF's Avatar
HannahF HannahF is offline
Laced in a Legacy
FRC #0433 (The Firebirds)
HannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant future
Originally Posted by eedoga View Post
This is the most entertaining release video, I have ever seen . Great Job! and good luck this season.
~Hannah
FIRST is like family and now my Family does FIRST!!
[2008-2011] Firebirds 433 Student, Head of Programming, Vice President
[2013-2015] Bambiebotz 4637 College Mentor
[2015-Present] Firebirds 433 Mentor, Strategy and Design
thisOrrthat thisOrrthat is offline
I <3 robots
AKA: Luke Orr
FRC #1730 (Team Driven)
thisOrrthat will become famous soon enough
Here is Team Driven 1730's reveal video. Enjoy.
Starscream is ready for action. See you all at the Greater Kansas City Regional along with the Queen City Regional. See you all there.
