Go to Post What does code sound like going though a complier? - Hiteak [more]
Unread 21-02-2012, 21:25
dictionaria13's Avatar
dictionaria13 dictionaria13 is offline
AKA: Marissa
FRC #3574 (High Tekerz)
dictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to alldictionaria13 is a name known to all
Things Learned During Build Season
As a rookie, I know I've learned a ton, not all totally FIRST-related. For example:
I learned that zip ties make effective hair ties,
I learned that I rock at crimping connecters onto wires,
A girl on our team who immigrated from Vietnam about two years ago learned about the kind of strippers you don't use on wires (she turned bright red when a guy on the team demonstrated by dramatically peeling off his sweatshirt).
I know I can't be the only one who's learned stuff like this. Anyone else want to share what's happened to them?
Unread 21-02-2012, 21:47
tsakshaug tsakshaug is offline
FRC #0340
tsakshaug is an unknown quantity at this point
Re: Things Learned During Build Season
As a mentor, I learned that getting changed to second shift at work makes it nearly impossible to work with the team
Enjoy every sandwich. --WZ
Unread 21-02-2012, 22:51
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Always design your robot to include wires and battery mounts. Also, don't give your head programmer 1 day to debug code. What he will do instead is write 40 lines of crap code just to do a unit test, and use the time between regionals to debug.... a very not so good idea.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 22-02-2012, 00:12
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Take "concept-freeze" day seriously.
Unread 22-02-2012, 00:31
Chomper2013's Avatar
Chomper2013 Chomper2013 is offline
Team 1672 President
AKA: Katie Clarke
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Student
Chomper2013 is on a distinguished road
My team's learned that the most popular question is "Where is the Wago/Measuring Tape/ Punch?"
Unread 22-02-2012, 00:32
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
Originally Posted by Wing View Post
[D]on't give your head programmer 1 day to debug code. What he will do instead is write 40 lines of crap code just to do a unit test, and use the time between regionals to debug.... a very not so good idea.
A better one: Finish the robot early so that the programmers have time to PROGRAM. Seriously, we need time to write and, more importantly, to test our code. My two years so far were awful because of this, and year three likely will be stressful again.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
Unread 22-02-2012, 00:37
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
What I learned during build season this year:
don't wire the PD board backwards. Bad things happen...
Unread 22-02-2012, 00:55
Jakester9999 Jakester9999 is offline
FRC #2073
Jakester9999 is on a distinguished road
I would also add, "Where is the 7/16" wrench?". Those will always be your go to wrench for FRC.
Unread 22-02-2012, 01:00
AKA: Elisha Sword
Oh. Happened to us too. We burned six Jaguars that way.
—Elisha Sword
Unread 22-02-2012, 01:06
nitneylion452's Avatar
AKA: Joe Lee
We learned that our Victor motor controller, which had never been used before, was bad. Our only experience with the famous victor, and it was negative. What are the odds?
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 22-02-2012, 01:20
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
What I learned during Build Season: I miss build season.
While being in college, I was still able to help out my team some times, but I truly miss the full experience.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 22-02-2012, 01:28
JohnSchneider's Avatar
JohnSchneider JohnSchneider is online now
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Yeah I drove 4 hours on the weekends to help...but it wasn't quite the same.
Unread 22-02-2012, 03:36
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Or you could down-size to "where's the 3/8ths" shifting to the lighter 10-32 screws and bolts.
This year learned that 3/16" rivets are over-kill. It will be 1/8 next year. and maybe thinner gussets too. Maybe even thinner-walled square tube. Who knows?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 22-02-2012, 03:57
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
My only suggestion would be to map outputs to Direct percent V-buss and force the drivers to deal with any complex cases. Last year the robot spent 30 min before bag with the programers, with no sensors. This year we pushed and got drive encoders, gyro, as well as several other sensors and will likely add one more at competition. Hopefully work to get some time in next year, a programer in a leadership position on the team really helps with this.
Unread 22-02-2012, 04:58
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Honestly, way too much. 973 has helped me as a mentor, grow and learn so much this year. Granted, I'm no AdamHeard when it comes to design and fabrication but with just a bit more help and examples I will be gaining the tools to eventually gain that potential. The past 6 weeks were stellar and the next 6 should be even more awesome.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
