Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 22-02-2012, 07:17
Billfred's Avatar
Billfred Billfred is online now
pic: Los Pollos Locos presents: Incocknito
Unread 22-02-2012, 07:18
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Los Pollos Locos presents: Incocknito
Looking good, good luck this season. Unfortunately we won't be in Palmetto this year to help defend the title with you.
Unread 22-02-2012, 08:17
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
We won't be there, either.
You guys will be the sole defenders of the Palmetto regional championship title.
Good luck.
The bot is looking good.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 22-02-2012, 08:24
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Can we get some specs on this beast?
I have no idea what is going on with the top of your robot and it looks very interesting.
Unread 22-02-2012, 09:52
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
It looks like the top is their version of a turret-less turret. I'd say that they can shoot from both sides, depending on the direction they run those IFI wheels. Ingenious, and simple.
As for the other specs, I'd like to know them too, particurally the angle on those plastic pieces, 'cause they look pretty darned steep...
Academic Student (Forever)
Unread 22-02-2012, 18:52
Billfred's Avatar
Some specs off the top of my head:
-Kitbot 6WD (and when I say "kitbot", I mean "kitbot"--we felt it met our needs bone-stock this year)
-Polycord elevator, with some PVC rollers on what I've started calling the Plinko board to corral the balls into the center line. (Our intake is theoretically two balls wide; we figured ball acquisition from the floor was a priority.)
-Bidirectional shooter designed to align against the field in certain positions for directional aim. (Not telling which positions, but you'll figure them out soon enough.) the shooter is a F-P through an AM Planetary and CIMple Box (then sped up again through chain and sprocket--it was just simpler to adjust that way) driving wedgetopped FIRST wheels. At Peachtree, we plan to switch that tread out for black SBR roughtop.
-Window motor bridge pusher in the rear (hidden behind the Plinko board) hooked to wheels. Voted Most Likely To Be Re-Engineered for lack of proper testing.
We're not 100% ready at this point thanks to some late-build cRIO issues (we may be ordering a fresh one considering this is the same chassis that conked out on us last year at Peachtree), but around here a saying has developed from that other USC team that's won two titles back-to-back: Win anyway. We've had amazing seasons from worse robots than Incocknito, and we expect to overcome whatever comes into our path.
Unread 22-02-2012, 19:09
CalTran's Avatar
Missouri S&T Senior
I would hazard a guess as to, taking into account the angle of those plastic pieces, you're butting yourself right up between the wall and the alliance station to fire off balls quickly, to rack up quite a few twos or threes
Unread 22-02-2012, 21:52
DonRotolo's Avatar
Back to humble
FRC #0832
Me, I'm thinking that your blue banners weren't flukes...
