Go to Post Dave was an evil genius in his previous life. - Koko Ed [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #31   Spotlight this post!
Unread 20-02-2012, 21:30
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Re: Performance Scouter
Here it is http://www.bearealis.com/gamesconten...oundRumble.exe
Steve
-Programming Mentor
- Team 578 Alumni
  #32   Spotlight this post!
Unread 20-02-2012, 22:34
Bryany's Avatar
Bryany Bryany is offline
FRC #1094 (Channel Cats)
Bryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the roughBryany is a jewel in the rough
Red face Re: Performance Scouter
Originally Posted by Wiifi View Post
I am missing a link for this year's version? I don't see it
Woops. I must have been a little tired. Thanks Steve!
I fixed the post, so the link is there as well now.
~Bryany
Free One-Person Powerful Objective Performance Scouting PC Program from 1094:
http://www.chiefdelphi.com/forums/sh...63#post1235263
  #33   Spotlight this post!
Unread 21-02-2012, 19:22
stundt1's Avatar
Steve
Bryan the program crashes when I try to put a picture for a team in.
Steve
-Programming Mentor
- Team 578 Alumni
  #34   Spotlight this post!
Unread 21-02-2012, 23:49
Bryany's Avatar
Thumbs up Re: Performance Scouter
Thanks! I forgot to update that part of the code, and negligently also forgot to test that part too. It should be fixed now.
Also, I fixed a graphical issue with the relative-skill meter not always fitting the meter-frame.
Keep sending in the feedback!
~Bryan
  #35   Spotlight this post!
Unread 22-02-2012, 00:01
stundt1's Avatar
Steve
Is there a update then?
Steve
-Programming Mentor
- Team 578 Alumni
  #36   Spotlight this post!
Unread 22-02-2012, 00:22
Bryany's Avatar
Yeah, it's the same link. If I ever mention a bug fix or a new feature, then it will be the current link.
~Bryan
  #37   Spotlight this post!
Unread 22-02-2012, 01:09
stundt1's Avatar
Steve
Can you add the ability to edit match information after its saved?
Steve
-Programming Mentor
- Team 578 Alumni
  #38   Spotlight this post!
Unread 22-02-2012, 01:51
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
I think you should have that they balanced on the cooperation bridge because it will show that they are very good with working with others.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
  #39   Spotlight this post!
Unread 22-02-2012, 10:49
Bryany's Avatar
Match data is added to each team's total scores, and individual match results are not stored. In order to edit individual matches, each match would need its own memory, and going through all those matches to find a team's total score would be strenuous. An alternative would be to save each of a team's match results in that team's section in addition to their total score, which wouldn't be as bad, but it would slow things down a bit, and there would be three sets of data that would have to be kept synchronous (total score, match score, and match schedule). I agree it would be a nice feature though.
Match schedules of course are already editable.
It seemed to me that balancing with an alliance-mate would be just the same as balancing with an opponent, since both would theoretically be giving the same effort to balance.
Separating 1 robot balance vs 2+ robot balance beyond just differences in score would be nice, but it would mean separating even more data categories beyond the main 6, and I'm trying to keep it simple.
  #40   Spotlight this post!
Unread 24-02-2012, 16:29
T Wallas Pog's Avatar
T Wallas Pog T Wallas Pog is offline
FRC #2993 (Megabots)
Team Role: Driver
T Wallas Pog is an unknown quantity at this point
It comes up with an error and won't let me continue when I try to change the team number.
  #41   Spotlight this post!
Unread 25-02-2012, 11:22
Bryany's Avatar
Hmm. Could you copy the error here? And just for clarification, this is changing the number on a team's box during a match, right? It's not doing it on my normal tests, so I'm wondering if there are special circumstances that throw this error. Does this happen every time you try it?
Thanks!
~Bryan
  #42   Spotlight this post!
Unread 28-02-2012, 15:44
Team Role: Driver
The error comes when I try to change The area that says "My Team" from 1094 to 2993.
ERROR in
action number 4
of Draw Event
for object obj_sched:
In script scr_sched_draw:
Error in code at line 88:
&& global.host != 0
at position 24: Cannot compare arguments.
  #43   Spotlight this post!
Unread 28-02-2012, 22:37
Bryany's Avatar
Post Re: Performance Scouter
ERROR in
action number 4
of Draw Event
&& global.host != 0
Thanks! Once I knew where to look it was a quick fix. Try redownloading it now.
~Bryan
  #44   Spotlight this post!
Unread 07-03-2012, 10:19
Bryany's Avatar
I've added a small change: Now the schedule is listed Blue then Red, instead of Red then Blue, since that's the order the official schedules usually are in. I've also sped up the schedule screen a bit.
~Bryany
  #45   Spotlight this post!
Unread 07-03-2012, 15:26
Bryany's Avatar
Okay, I've altered the table to show both single-balancing and multi-balancing during the endgame. Right now, the data entry section does still have a spot for you to enter defense points, and it will save that defense data to the file, but it won't appear in the table.
Soon I will remove the defense entry altogether, unless there are any objections.
Do test this out, I made the change somewhat hastily. I plan on testing it myself, but I'm a bit rushed right now. Just click twice on the balance button to enter multi-balance.
~Bryany
[IMG] code is Off
