Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 22-02-2012, 09:26
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Obscured bumper numbers?
I noticed a few robots have appendages that obscure the team number when the appendage is in use.They range from a thin bridge arm that splits the number to a full ball collector as wide as the bot. Legal or not? I really don't know but my gut says illegal based on the number of bots that did not block the view of the number or am i getting into that shaddy area of rule intent.
Unread 22-02-2012, 09:35
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Obscured bumper numbers?
Only rule I can find relevant to this is R35, which according to my interpretation, requires that a robot be able to be clearly identified from 100ft away. If a robot can still be identified from that distance, even with a blocked number (appendage) then the rule is met, IMO.
[R35]
Teams shall display their team number on the Bumpers in four locations at approximately 90° intervals around the perimeter of the Robot. The numerals must be at least 4 in. high, at least ¾ in. in stroke width, and be either white in color or outlined in white. Team numbers must be clearly visible from a distance of not less than 100 ft, so that judges, referees, and announcers can easily identify competing Robots.
Then if you look in the Q&A you'll find this:
A. Per [R35], team numbers must be clearly visible. This means that they may not be inverted, obscured, fragmented, upside down, etc. Bumpers that wrap around a corner are likely to be considered fragmented and not able to be seen in their entirety.
According that the GDC's interpretation, if the numbers are obscured, you're not in compliance with R35?
Seems like there's the common sense interpretation of this rule and the literal interpretation of the rule. Maybe someone should ask in the Q&A?
-Dustin Benedict
Unread 22-02-2012, 09:55
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
If you're unsure, put your team number up on the robot somewhere as well! That way, when the bumpers are obscured by your manipulator, the number is still visible just above them.
Unread 22-02-2012, 10:07
FRC #0910
Jon, that doesn't solve the obscured number rule. You could almost read the rules as the only place you can have team numbers is on the bumpers this year. I said almost.
Unread 22-02-2012, 10:54
thefro526's Avatar
Mentor for Hire.
As far as the bumpers go, they're pretty picky about the numbers and how many times you're allowed to have them.
A. Rule [R35] requires that the team number be displayed in four locations, no more or fewer.
Seems like having the number elsewhere would solve the issue of it being blocked by an appendage, though you'd still technically be in violation of R35.
-Dustin Benedict
Unread 22-02-2012, 11:14
Mentor, LRI, MN RPC
Look at it from the intent/spirit of the rules. There's nothing ruling against having an appendage that covers your bumper - in fact, such an appendage is pretty much necessary to manipulate the bridge, which is part of the game design. If that covers your team number on that side, its still visible on the bumpers on the other sides.
As for R35, the GDC is really going for readability. As a thought experiment, lets imagine the GDC hasn't been as picky about the numbers as they have been. You get to competition and teams 20 and 2020 are both there. Team 20 decided they wanted to display their number on both sides of their ball gatherer so its equally visible from multiple angles and for aesthetics, especially if a manipulator is lowered between them. Team 2020 decided they wanted to split their number on both sides of their ball gatherer, so it wasn't squished on one side, and for aesthetics. Now, looking at the front of the robot, the team numbers look identical - 20 on the left, and 20 on the right. How do the refs or scouters know which is which at a brief glance?
The whole intent of the bumper team number rules is to ensure that the numbers are readable and teams won't be confused. It helps the refs on the field, it helps the scouters in the stands, and it helps the friends/family that come to cheer your robot on.
If you have an appendage that blocks your team number on one side of the robot, and you know that appendage is going to be deployed most of the match, you'll likely want to put your team number above the bumpers on the robot somewhere - R35, and the GDC's quoting it in the Q&A should only apply to bumpers, not to what's displayed on the robot - anything displayed on the robot is a non-functional decoration, and the only real limits on those are that it can't interfere with other teams vision detection..
Unread 22-02-2012, 11:16
A test for me would be the answer to this question. "How long does your appendage cover the numbers on your bumper?" If the answer is 'most of the match', 'the entire match' or 'as soon as auto starts' I would think you have crossed into the "obscured" definition. If the answer is 'only when we are picking up a ball' then I would think that prudence suggests that you are not obscuring the number.
Unread 22-02-2012, 11:28
FRC #0910
What do you say to a team that built their bot so that the bumper numbers are clearly visible during the whole match and they lose to a team that has a harvester down the whole match obscuring the team number? Maybe i'm reading to much into this but i feel this might cause some anguish at comps this year.
Unread 22-02-2012, 12:16
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I know past years rules do not apply to the current game. But the combination of appendage & locomotion game piece would obscure the number on our bumper. Nothing was ever said. of it.
I do not think the inspectors will make an issue unless it was obvious that obscure to the number was the intent. Just who was that masked robot anyway?
Unread 22-02-2012, 12:47
FRC #0910
Devils advocate- " Head ref, head ref!!!! I know we just got beat in the finals but according to Q&A that teams bumpers were obscured during the match."
Unread 22-02-2012, 13:56
From the inspector standpoint, we check the bumpers for compliance and then check for appendage projection. We do not inspect for how the robot acts on the field. If the head ref calls us to check on something that he/she sees during repeated matches we will report back our findings and then make a decision. The head ref, LRI and FTA discuss items throughout the weekend and when needed will come to a consensus or call for a better decision. We each have appropriate phone numbers, one of which is the head guy. LRIs have my phone number.
Unread 22-02-2012, 14:07
Aren_Hill's Avatar
Build Nifty Things
Q. Can the bumpers be covered at any point by a dynamic appendage on the robot?
A. There are no rules prohibiting this.
from early on in build season
A guy who likes robots.
Unread 22-02-2012, 15:57
FRC #0910
I guese someone would have to ask if team numbers on bumpers......but nobody will, alittle late in the season.
Unread 22-02-2012, 16:23
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Is it just me or is this bumper rule stuff getting a tad ridiculous. I know people want to see our team number but come on this is crazy there is more engineering going into the bumpers than the robot...
Every day is a new adventure!!!
Unread 22-02-2012, 16:29
Mentor, LRI, MN RPC
In a lot of engineering projects, you spend more time working on the "boring" specs the customer wants, instead of the "fun" aspects of the project. When designing a new car, not everyone can work on designing the engine. You still need to design the door handles, trunk latches, and all the other small, boring parts that are in a car.
