Go to Post Naw, basketball isn't nearly as great a sport as FRC. They play for the money. We play for honor, dignity, and respect. - synth3tk [more]
Unread 22-02-2012, 12:56
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Battle of the Middle Bridge
I’m seeing a few designs that imply tilting the center bridge in hybrid and I expect we’ll see a few instances when robots from both alliances attempt this. The big question is - who will win/survive the ensuing teeter-totter battle.
Unread 22-02-2012, 12:57
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Battle of the Middle Bridge
The one that gets there first.
Hi!
Unread 22-02-2012, 12:58
Andrew Lawrence
Posts: n/a
That, or the one with the most torque applied at the best angle.
However, like Taylor said, the one that gets there first will win, all the time.
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
There's something to be said for the one who pushes harder, too
Unread 22-02-2012, 12:59
Taylor's Avatar
AKA: @taylorstem
By that time, the bridge is pushed up out of reach.
Hi!
Unread 22-02-2012, 13:00
Depends on your reach.
Unread 22-02-2012, 13:04
Andrew Lawrence
Posts: n/a
Whatever it is it won't be past 14".
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's one reason I'm glad we didn't get around to programming that feature in our autonomous code....another is that last year we kind of tore up our robot by having it drive too far in auto most matches.
Unread 22-02-2012, 13:22
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
The challenge is getting there asap without driving full speed into a raised bridge...
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 22-02-2012, 13:33
Agreed, first in wins - what if it's a tie? It becomes a force game and that is when it becomes intresting...broken arms, 2 foot drops or a flip are all possible.
Unread 22-02-2012, 13:35
Andrew Lawrence
Posts: n/a
So that brings up a good question: Which is more important? Scoring the balls you have in hybrid, or getting the balls off the bridges onto your side.
To quote my favorite announcer: Let's do the math:
In hybrid mode, each robot starts off with two balls, and there are two balls on each bridge, assuming all 6 robots use both of their allotted balls.
The score in hybrid mode is (normal_score + 3), so each ball is potentially worth 6 points. That's 36 points if all 3 robots score both of their balls in the top hoop during hybrid, which will require some coordination, meaning there will be a first robot, a middle one, and a last one, most likely shooting in the end of hybrid.
If you use hybrid mode to get all balls off the bridges and onto your side (one bridge per each robot on the alliance), than you will have 12 balls on your side, a little more than each robot can handle. If all 12 of those make it to the top basket, it's worth 36 points.
So in the scenario of going for the bridge vs. going for the points, both will give you 36 points.
Now let's mix it up a little. Say you have all 3 robots taking turns shooting in hybrid, but the first robot goes for a bridge once it's done. That's the 36 points of hybrid from all 6 balls, and +6 points for the two balls that were on the bridge, assuming they were scored in teleop, giving an almost instant score of 42 points.
New scenario: The same thing is done, but with the 2nd robot also going to a bridge. By this time, the first robot probably got the balls off of its bridge down, and the 3rd robot is getting ready to shoot. There are only two bridges left, and chances are your opponents will be going for a bridge as well. IF your second robot gets the balls onto your side, that's another +6 points for your alliance, getting you to a score of 48 points, 12 points above your opponents.
In conclusion, the balls on the bridge will only improve your score if you can gather them AND have all 6 robots on your alliance score in hybrid mode.
Just something to think about when doing autonomous strategies.
Unread 22-02-2012, 13:38
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Here's one of ours It's not an easy thing to do quickly without risk of careening off balls and missing your mark etc. A bot that could to this while shooting/making baskets would be quite an asset.
www.179swampthing.org
Unread 22-02-2012, 13:44
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
The team with the Kinect that can do it in conjunction with the arm with the most apropos application of torque and an arm that can has options.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 22-02-2012, 13:46
An aggressive strategy would be - shoot both of your allocated ball and then go for the middle bridge. The remaining bridge balls are off limits to the opposing alliance.
Andrew Lawrence
Posts: n/a
Agreed. The team using the kinect will have the most control over their robot during hybrid, so they will most likely be the ones getting the bridge down the fastest. And the implementation of commands to change the robot speed at will will be pretty helpful.
