Go to Post These are words on a computer screen, please stop giving the text on this screen such incredible power over how you feel. - Stephen Kowski [more]
Unread 21-02-2012, 22:37
kuh-nig-its-EL's Avatar
kuh-nig-its-EL kuh-nig-its-EL is offline
FRC #1939
kuh-nig-its-EL is on a distinguished road
Exclamation CAN failure!!!!!!!!
Okay this is vital to our robot and it's ship day. CAN runs perfectly when we run it from bdc-com. Now with any form of code it will not work. The example won't work and real code doesn't work. I can't find any other threads with solutions. The error we are seeing is MCOMM_CAN_Send.vi (insert number here) cant execute and that it's timing out. Please help.
Ethan Lopez
Unread 21-02-2012, 23:00
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: CAN failure!!!!!!!!
Did you enable the driver through the cRIO imaging tool? You need to set it to either the 2CAN plugin or the Serial plugin using that for it to work
I'm right 90% of the time, so why worry about the other 3%?
Unread 21-02-2012, 23:07
FRC #1939
Yes we have CAN enabled as a serial bridge
Unread 21-02-2012, 23:21
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Do you have Console out enabled? What does your intialization code and wiring look like? 1 always has to be connected to the cRIO first.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 21-02-2012, 23:28
FRC #1939
We ran the example code and i did exactly as it instructed to run the code, i changed the IP to 10.19.39.2 and we have only one CAN jag and it is wired into the crio through a serial port and it has the terminator attached as well. I don't know about console out.
Unread 22-02-2012, 08:46
Make sure it's off. The console's serial communication will interfere with the CAN serial communication. Are you using an older 8-slot or a newer 4-slot cRIO?
Unread 22-02-2012, 08:52
FRC #1939
We are using the newer 4 slot crio. On the console out part, all i know is that it was switched to the left (not towards the modules).
Unread 22-02-2012, 11:32
AKA: noops
Please tell me you have withheld your cRIO or have a backup. It would be very hard to debug code if you didn't. if you have, I would try and reimage the cRIO. On the 4 slot, the DIP switches are not hardware switches. Remember, when you are downloading code, have Console Out be on if you want console feedback, off if you don't need it. Make sure your CAN cables are correct. Also, are you using the BlackJaguar or the Grey/Tan one? Only the BlackJaguar has a CAN bus on it.
Unread 22-02-2012, 14:26
FRC #1939
I will double check the the console out switch when i get a chance we do have a back up crio. We are using a black jag.
