Go to Post Perfection is less about effort or skill than it is about having a clear and limited goals. - SoftwareBug2.0 [more]
Unread 13-02-2010, 08:03
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Electrical Connection for Denso Window Motors
Hi, has anyone figured out what connector will "plug" into the Denso window motors? I'm headed to the auto parts store today, but it would have been nice if they gave us plug connections to go with the motor.
We've spent a lot of time holding two wire against the leads like Operation
Unread 13-02-2010, 08:36
Electrical Engineer
Rookie Year: 1995
Re: Electrical Connection for Denso Window Motors
What I have done in the past is to use appropriately sized slip on connectors (female disconnects) with electrical tape around one to prevent shorting (unfortunately, the fully shrouded ones are too big). Then I fill the connection cavity with 5-minute epoxy creating a permanent "pig tail" to the motor.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-02-2010, 11:00
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We just use a Dremel tool cutting wheel to cut away the top part of the shell and solder wires directly to the pins. We usually have little pigtails with Anderson Powerpole connectors on the end for easy changing of the motor: http://www.powerwerx.com/anderson-po...pole-sets.html
Unread 13-02-2010, 12:58
Gdeaver Gdeaver is offline
FRC #1640
I'll see if I can get the Delphi connector and pin numbers today. Mouser carries them.
Unread 13-02-2010, 14:12
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Connector from Mouser Electronics: PN 829-12129487.
Metri-Pack terminal from Mouser Electronics: PN 829-12129493.
Taken from http://www.chiefdelphi.com/forums/sh...or+conn ector
Unread 13-02-2010, 22:18
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Travis Hoffman View Post
Ahh, is there anything that Search can't tell us?
Nice find
Unread 21-02-2010, 17:10
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Nice find
CD search is my friend, a mentor of mentors.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 03-02-2011, 14:45
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
Make sure you order the housing AND the connector. Two part numbers. Guess who just recieved a box of worthless housings today!
Unread 10-02-2011, 07:37
Jake bonczyk's Avatar
Jake bonczyk Jake bonczyk is offline
Jake
FRC #1918 (Nc gears)
Jake bonczyk is an unknown quantity at this point
here are the parts needed to make the connector for the window motor the following are
Packard parts
1pc 12129487 connector
1pc 12077904 TPA(lock)
2pcs 12010293 seal
2pcs 12110845 terminal
You should be able to get them anywhere you can get Packard connector parts
you might need some wire
Unread 18-02-2011, 18:11
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
How do you search Packard by product number?
I would put a signature here, but that's too mainstream
Wait a moment...
Unread 22-02-2012, 15:14
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
From above:
I ordered them. The connector is right the terminal is not. This one has the tangs in the plastic and just a slot on the terminal (pdf drawing here) This terminal has the tang feature on the terminal.
I have hunted around on the Mouser site I THINK this is the right terminal (Mouser PN 829-12129493, pdf drawing here) I will confirm once I have parts in hand.
Joe J.
Team #88, TJ2
Unread 22-02-2012, 16:07
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
From the KOP check list:
Connector: 12129487
Terminal: 12110845
Part Number Search on Mouser using the above numbers yields:
Connector: 829-12129487
Terminal: 829-12110845
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 22-02-2012, 16:12
O-H
Connector: 12129487
Terminal: 12110845
Yup - Delphi donated window motor connectors and terminals in each KOP this year.
Denso WIndow Motors, torque. John G Motors 1 29-01-2010 21:25
Ampage for the Denso Window Motors. Joshamuffin Motors 1 07-02-2009 17:42
Need to find connectors for Denso Window Motors. Joshamuffin Motors 0 07-02-2009 11:19
Window Motor electrical connection Andrew Schuetze Motors 8 14-02-2006 09:58
