Go to Post I fear not the drive team who has practiced 10,000 defenses once, but I fear the drive team who has practiced one defense 10,000 times. -Bruce Lee - bEdhEd [more]
Unread 22-02-2012, 13:47
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Robots can't count: Microswitches
We are using a microswitch on our robot to add and subtract the balls. The MicroswitchesWe are plugged with GND on C and SIG on NO (normally open).
I will add the code when I get the chance but it is basically:
Int totalBalls = 2
public int microSwitch(int totalBalls)
If (addball.get() = true and totalBalls >= 0 and < 3
Then totalBalls += 1
If (minusball.get() = true and totalBalls > 0 and <= 3
Then totalBalls -= 1
Else if totalBalls > 3 || totalBalls < 0
Then totalBalls
return totalBalls
When I hit the switch, it calculates the addition or subtraction, but when the switch is released, it goes back to the original value. Why an't a robot count?
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 22-02-2012, 15:18
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Re: Robots can't count: Microswitches
If your pseudo code matches your real code, the module level variable totalBalls defined at:
Originally Posted by NS_Radication View Post
Int totalBalls = 2
Will never be updated because the variable totalBalls defined as a argument to your method will take precedence.
Try renaming the module level variable to m_totalBalls or another name. Also, you only need to check the upper limit when adding:
If (addball.get() = true and totalBalls < 3
And the lower limit when subtracting:
