Go to Post Comments and Documentation: Use them! You would never believe how fast you will forget how something works, especially when things are flying at you so fast. Other/future programmers will understand what you did and why you did it. - BigJ [more]
Unread 22-02-2012, 15:58
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: 2084 Mecanums with Worm Drive
I'm excited to see more teams using worm drivetrains,
Can your robot be pushed with mecanum wheels?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 22-02-2012, 16:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'd be a little frightened of a non-backdriveable drivetrain. I'd be especially worried about using the WormBox with its standard nylon wormwheel. At the very least, I'd put the robot on some carpet and shove until the wheels gave way to convince myself I wasn't going to shear teeth in a shoving match. I'd really want to run a robot into your robot at a decent clip to make sure the shock load on those gearboxes isn't going to destroy them.
Unread 22-02-2012, 16:54
Aren Siekmeier's Avatar
on walkabout
Originally Posted by Kevin Sevcik View Post
I'd be a little frightened of a non-backdriveable drivetrain...
The Andymark WormBox is backdriveable from what I've seen. They had a test chassis at IRI last year, and was quite capable of being backdriven.
Unread 22-02-2012, 17:22
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
We've done a lot of stress testing and haven't found any problems. The gearboxes are backdrivable, but it's very hard to do.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 22-02-2012, 21:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
But even if the gearboxes are able to handle it, there probably is not enough frisction.
Unread 22-02-2012, 22:17
Djur's Avatar
WPILib
AKA: Sam Carlberg
Not enough friction for what? If a robot tries to push us sideways, the wheels won't turn.
